Who need's a tapmatic anyway
tbark
Spammer. Have I told you about my crappy auction s
BANNED
Hello All Awile back a fellow told me about using his electric screwdriver and a chuck that was made for it to tap liner's for screws I tryed it this morning and it work's out just fine I spun in 10 holes to threaded holes in about 2 min. using the 256 tap chucked up in my little screwdriver it also worked on 3/32 ats-34 went right through just fine no problem at all so that is my contribution for this week
TbarK Custom Knives
http://vip.hpnc.com/~tbark Therefore I erge you brother's in view of God's Mercy to offer your body's as living sacrifices holy and pleasing to God-this is your spiritual act of worship Romans 12-1
That sounds really easy. How big of a screwdriver/cordless drill did you use? I have a 9.6 volt dewalt. I'm guessing it would have to be set on the lower of the 2 speed settings. It has an adjustable clutch to, should that be set at the lowest to avoid tearing out?
Fix it right the first time, use Baling Wire !
Tbark, what kind of cutting fluid do you use, or do you just dry tap em?? Thanks! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
I normaly just use lite cutting oil like tap-magic
I posted that one several months ago.
I use a Skil Plus rechargeable screwdriver. It works great up to 4 x 40. For larger taps up to 10x32 I use a 9 volt rechargeable drill. For the really big taps I use a 19 volt drill. Taps last longer, especially the smaller ones and you don't break them as often.
I guess someone will ask - why don't you get a Tapmatic for the drill press? Just been doing it so long this way and if it's not broke, why fix it?
Mike, I use Winbro Tap Free, but I don't think you can buy it any longer.
Les halpern is the one who told me about it I just use a cheepo black and decker bottom of the barrel job it does fine for me
TbarK Custom Knives
I just Hold it in my hand ang get it fairly Streaght and away it goes I like doin it so much I tapped 3 xtra holes this morning hehehehehehe
TbarK Custom Knives
