Thanks for pointing me here Firestrike,
Good Morning Gents,
The Battle Saw looks very similar to the ASHBM so I imagine the patterns we have will work for it with only slight mods needed. Honestly, the saw teeth issue is not an issue. I've built more than a few sheaths for them and they are still going strong, Saw backs have been around for quite some time. You have to intentionally work at it to cut through the welt on a properly built sheath. The Mistress sheaths we build use a double welt and 10 ounce leather, if you manage to cut through it, you send it to me and I will build you a better one, plain and simple.
I generally only do open spine sheaths on Kukri's or odd shaped knives. With the teeth forward facing on this one, you will not like accidentally dragging your hand or wrist on it.
I'm fine with a Group Buy for you guys, I would go with our Gaspee belt design that I build for the TGLB, obviously it will be a bit bigger for the BS. Removable Drop Loop and a built in tie down are standard on this large of a sheath as is the Rapid Release System. I normally charge 92.50 for this design in that size. If you guys want to get a minimum of ten sheaths I will drop them down to 80 shipped and can have them done in 5-7 days after I get a BS in to work with, excepting sheaths that have add ons added, pouches, firesteels, Baldric etc. If we keep it simple it goes fast, but you are welcome to add on whatever you need. I would rather build you the sheath you want rather than the one that is quickest.
I can build them in 5 different colors, with 9 stitching colors available. They do not all need to be the same, You are welcome to any configuration you want to order. It all cuts and stitches together the same to me and I won't get bored hand stitching 250 feet of thread
If we get 10 or more 'I'm In', I will set up a Group order sheet on the website where you can pick your color and draw options. Everyone would then have 5-7 days to get their order in so I can get the batch cut, done, and shipped together, I imagine Firestrike would like to have his Battle Saw without waiting longer than necessary for stragglers to order.
Gaspee Design
Leather Colors
http://patriotleatherco.com/leather-colors.htm
Stitching Colors
http://patriotleatherco.com/color-chart.htm
You are welcome to email me questions
