50% more vanadium, 3.4% C to 10V's 2.45% C
sounds like it would make a good kitchen knife though..
but no hard use
You don't really want to use this stuff. Its just plain NASTY! I have surface ground it on a couple of occasions, and even going across a small surface was bad. The 46 grit wheel would go dull and start squawking before finishing a single .005" pass.
I've mostly seen it used in stamping forms where carbide wouldn't hold up. If its a replacement for carbide, expect it to be tough to work with. Its mostly finished in its hardened state with wire EDM.
JP
i call DMT a must for anything over s30v
so far as 15v in the kitchen i think that it would be far to coarse an edge to be good on any thing other then meat prep as a thick edge and sub 600 grit sharpening would not be good on vegetables
I've sharpened up my S90V knives on my Sharpmaker's white ceramics no problem.
You can't take the edge on a 15V knife past 600? What about DMT stones?
not to sayit cant be done but the steel is so toothy anyhow cause of the carbides that there might be little to be gained Vs time spent honing
btw i too have the spyderco fine and ultra fine bench hones (ues on my razors )
also DMT 325 600 1200 was thinking about the XXf but im now gettign more into Jp. hones 5K and 10K for razor work
you're going to have carbides in steel, because of the carbon. Cementite is iron carbide. Also, you can have very very fine carbides, such as in AEB-L or 52100 when HT'd well.
