- Dec 7, 2000
Yesterday I went to Walmart and bought a $15 palm sander, made my Micarta plate, put some sand paper on that baby, squirted some Cool Tool II on it and fired the sucker up... Whoa!
Wear an apron if you value your tshirt.
So I turned it off, let my heart return to normal speed, set it firmly on the blade and turned it on... Ah, much better.
Before long I was confidently sanding away, moving in on my plunges (this is the first knife where I made an attempt to round them off rather than allow the square step from the ricasso), moving out along the tip... Worked from 220 through 400, 600 and finally 1500. The whole process took about 40 minutes for a 7 inch blade. (Keep in mind I had to figure out things like Just use a quarter sheet to start with, and Read the directions on how to attach the sheet...
Then I used a small sanding block backed with some latigo tanned leather and with dry 1500 stroked the twirlies out... Ah, beautiful, just beautiful. This is without doubt the best finish I've gotten so far and with less time and expense than any other way I've ever done.
Bless Bruce Evans and Alex Daniels!
Dave
