Whole LOT of mill bits
Feedback: +1 / =0 / -0
I am selling these mill bits which are new and in original packaging, I pulled prices from Amazon & MSC Direct. Asking $400.00 plus shipping for the whole LOT
•ATLAS A55467 $14.20 ($71.00) – Quantity =5 - 1/8" Carbide End Mill, 2 Flute, Corner Radius, ALTiN Coated- 1/8" DIA. X 1/8" SHK. DIA. X 1/2" LOC X 1-1/2" OAL - RADIUS - 0.030 - A55467
•ATLAS A49930 $ 14.20 ($56.80) – Quantity =5 - 1/8" Carbide End Mill, 2 Flute, Corner Radius, ALTiN Coated- 1/8" DIA. X 1/8" SHK. DIA. X 1/2" LOC X 1-1/2" OAL - RADIUS - 0.02 - A49930
•ATLAS A48179 $ 6.79 ($40.74) – Quantity = 6 - 1/8" (.1250) DIA. Carbide End Mill , 2 Flute , Stub, ALTiN Coated- 1/8" (.1250) DIA. X 1/4" LOC X 1-1/2" OAL
•ATLAS A48183 $11.81 ($35.43) – Quantity = 3 - 1/4" (.2500) DIA. Carbide End Mill , 2 Flute , Stub, ALTiN Coated - 1/4" (.2500) DIA. X 1/2" LOC X 2" OAL
•ATLAS A48185 $20.51 ($40.02) – Quantity = 2 - 3/8" (.3750) DIA. Carbide End Mill , 2 Flute , Stub, ALTiN Coated - 3/8" (.3750) DIA. X 5/8" LOC X 2" OAL
•ATLAS A51078 $15.83 ($79.15) – Quantity = 5 - 3/16, HSS End Mills, 2 Flute Square End, 30º Helix - 3/16" DIA. X 3/8" SHK. DIA. X 9/32" LOC X 2-5/16" OAL - A51078
•ATLAS A48148 $5.40 ($54.00) – Quantity = 10 - 3/32" (.0938) DIA. Carbide End Mill , 4 Flute , Stub - 3/32" (.0938) DIA. X 3/16" LOC X 1-1/2" OAL
•ATLAS A55310 $72.31 – Quantity = 1 - 1/2" Carbide Rougher/Finisher, 4 Flute , Corner Radius, ALTiN Coated - 1/2" (.5000) DIA. X 1/2" SHK. DIA. X 1" LOC X 3" OAL - Radius .040 - A55310
•ATLAS A47089 $29.78 – Quantity = 1 - 1/2" (.5000) DIA. Carbide Countersink , Six Flute , 60 Degree - 1/2" (.5000) DIA. X 1/4" SHK. DIA. X 2-1/2" OAL -- SIX FLUTE
•ATLAS A51078 $15.83 – Quantity = 1 - 3/16"DIA. X 3/8" SHK. DIA. X 9/32" LOCX 2-5/16" OAL, End Mills HSS Square End/2 Flute S.E. Uncoated
•ATLAS A59317 $34.26 – Quantity = 1 - 3/8 DIA. X 3/8 SHK DIA X 2-1/2 OAL - 4 Flute - Solid Carbide ALTIN Coated - Chamfer Mill - 82 Degree
•ATLAS A59334 $ 40.67 – Quantity = 1 - 5/16 DIA. X 5/16 SHK DIA X 2-1/2 OAL - 2 Flute - Solid Carbide - Chamfer Mill - 60 Degree - Double End
•ATLAS A59333 $31.62 – Quantity = 1 - 1/4 DIA. X 1/4 SHK DIA X 2-1/2 OAL - 2 Flute - Solid Carbide - Chamfer Mill - 60 Degree - Double End
•RTS PRESTIGE 08862104 $20.72 - Quantity = 1 - Solid Pilot Counterbores; Fastener Size Compatibility (Wire): #10; Standard or Oversize Pilot: Standard; Counterbore Diameter (Inch): 21/64; Shank Diameter (Inch): 5/16; Counterbore Material: High Speed Steel; Number of Flutes: 3
•HERTEL 84509678 $15.37 – Quantity = 1 - Ball End Mills; Mill Diameter (Inch): 7/32; Number of Flutes: 2; Material: High Speed Steel; Length of Cut (Inch): 1/2; Finish/Coating: Uncoated; Overall Length (Inch): 2-3/8
•HERTEL 41117102 $19.81 – Quantity 1 - Ball End Mills; Mill Diameter (mm): 4.76; Mill Diameter (Inch): 3/16; Mill Diameter (Decimal Inch): 0.1875; Number of Flutes: 2; Material: High Speed Steel; Length of Cut (mm): 12.70
•INTERSTATE 08860066 $12.48 ($24.96) Quantity =2 - Solid Pilot Counterbores; Fastener Type Compatibility: Fillister-Head Screw; Fastener Size Compatibility (Wire): #6; Standard or Oversize Pilot: Standard; Counterbore Diameter (Decimal Inch): 0.2410; Shank Diameter (Decimal Inch): 0.2500
•INTERSTATE 08862088 $19.78 ($39.56) Quantity=2 - Solid Pilot Counterbores; Fastener Size Compatibility (Wire): #8; Standard or Oversize Pilot: Standard; Counterbore Diameter (Inch): 19/64; Shank Diameter (Inch): 1/4; Counterbore Material: High Speed Steel; Number of Flutes: 3
•INTERSTATE 08862062 $19.78 ($39.56) Quantity=2 - Solid Pilot Counterbores; Fastener Size Compatibility (Wire): #6; Standard or Oversize Pilot: Standard; Counterbore Diameter (Decimal Inch): 0.2420; Shank Diameter (Inch): 7/32; Counterbore Material: High Speed Steel; Number of Flutes: 3
•INTERSTATE 08862062 $31.00 – Quantity = 1 - Interchangeable-Pilot Counterbores; Counterbore Diameter (Inch): 1/4; Shank Diameter (Inch): 15/64; Number of Flutes: 3; Counterbore Material: High Speed Steel; Aircraft-Style (Yes/No): No; Finish/Coating: Bright
•INTERSTATE 01884089 $20.32 – Quantity = 1 Ball End Mills; Mill Diameter (Inch): 1/8; Number of Flutes: 2; Material: Cobalt; Length of Cut (Inch): 3/8; Finish/Coating: Uncoated; Overall Length (Inch): 2-5/16
Total Retail price $847.17
Thank you,
Sean
Interested in these, Sean, could you please email me at elp2and3 (at) gmail.com
I don't have the ability to PM you.
Thanks, Earl Poole
