Why all the Opinel rave?
If you were in a store that had every knife made and had $10-$15 to spend, what would you buy? You need a knife and need to get the best cutter you can.
I'd buy a fixed blade. At that price I'd imagine it would be a couple steak or paring knives. I've got a paring knife that was free that cuts every bit as well as a opinel. In addition because it's a full tang knife it's going to stand up to abuse better than the opinel if I had to abuse it.
OK, I shoulda said folder. My bad. You see what I mean though, don't you?
As I said in my first post in this thread, Opinels are not for everybody. They are finicky and crude out of the box.
Still, I think there are several aspects of your review of the tiny #6 that doesn't apply to the larger Opinels.
I bought my wife an Opinel #6 (INOX) as she favors the old-fashion design.
Out of the box, it was flat dull - glinting along the entire edge, completely unsharpened at the heel. No big deal, didn't expect much anyway, and it sharpened-up easily being so thin, 15-dps microbevel. I like that the knife locks closed. But the blade-pivot was so tight, it was difficult for my wife to open. I read online, took a heat-gun to dry it out and the pivot was nice and loose, so loose that if it is NOT locked closed, it falls open freely, which my wife did not like.
Right. The blades come with grind marks which, if you want even better performance, need to be polished out. The edge should be done to your taste, as you did (more on your choice in a minute). Also the joint usually needs tuning and often the handle some reshaping to match personal tastes. An old timer suggested to me to think of an Opinel like a Tandy leather kit. It's a starter project to "make" a knife. This isn't for everybody.
The blade steel is Sandvik 12C27 at 58Rc. That's a nice fine grained steel at a decently hard Rc level. But there are limits and my sense is that 15-dps is beyond the limit of the steel unless you restrict the use to simple straight cutting. I'm not surprised you ran into problems. I use 20-dps for EDC use and 25-dps for really hard abusive work. As with any knife steel, I think you need to match sharpening to the job and the steel. Compared to other mid-grade steels like Buck's 420HC, Case's Tru-Sharp, Victorinox's Inox, CRKT's Aus-8, my experience with Opinel's Sandvik is that it is as good or better than any of those. My sense here is that you simply choose to sharpen it at too acute of an angle for any reasonably hard mid grade steel.
Regarding tuning the joint to control the tightness, I think you got a hold of bad information. The hair dryer trick (or hot sunny dashboard) will dry out the wood which cause huge swings in the tightness. IME, its much better to soak the joint in mineral oil or vaseline to stablize the tension and then set the tension by adjusting the inner collar. I describe this here:
https://dl.dropbox.com/u/28597626/tuning-opinels.txt
This is super, super, super fiddly and if you're expectation is to take a knife and use it out of the box without this sort of fiddling around, then I think knives from Victorinox or Buck or CRKT or many others will give a better out of the box experience. I can't say this enough. Opinel's are very fiddly knives and not for everybody. They demand that you learn or figure out how to manage the joint tension and that happens only by word of mouth. You don't know how to (which is to be expected, they don't come with instructions) and you didn't get particularly good advice, so I can't fault you for having a bad experience in this regards. All I can say is that the friction of the Opinel can be tamed, even in humid, wet New England but its pretty darn fiddly.
It doesn't open easily and safely with one-hand like most modern folders.
It's a manual lock, no springs but able to be operated one-handed, but it's less convenient than most lock-designs, another thing my wife recognized.
As a traditional, it has no pocket-clip so must be carried in a pocket/pouch/sheath of some type, something that both my wife and i found annoying.
The #6 that you purchased is the size of a small slip joint. About 3 1/2" closed. A mere 1.2 oz in weight. I'm not I've ever talked with anybody who looks for one hand opening in a small pocket knife, but I suppose if that's something you want.
The Opinel's change dramatically as you go up in size. IMO, the #9 is the first one that starts comparing to favorably to modern pocket clipped one hand openers. Guys I know who use the larger #9 and #10s in the trades tell me they file out an easy-open indent to make one hand opening easier. Here's a #10 with an easy open indent. Very easy to one hand open.
Buck 110 and Opinel #10 by Pinnah, on Flickr
With respect to pocket carry... I'm honestly shaking my head. At a mere 3.5" and 1.2 oz, there just isn't a more comfortable non-clipped pocket knife than the Opinel #6. I really can't imagine what you would possibly want more in a pocket knife in terms of comfort. The only thing I can think is that you and your wife are used to pocket clips and at this point, nothing other than pocket clip will satisfy you. That's not the fault of the Opinel.
Finally in use, the edge geometry is great but the edge-retention is very poor, requires touching-up OFTEN to straighten or restore the apex, unlike many of my other knives.
No. The Opinel has a great built in blade geometry. It's convexed above the micro-bevel to the spine. That is it's secret.
The final edge geometry is something you can and did control. You pushed a good mid-grade stainless to 15-dps and that's why you saw edge rolling. If you want to compare edge retention, you really need to compare Opinel's 12C27 to other similar steels like 440A, 420HC, Vic Inox or Aus-8. In that group, Opinel's Inox is at or among the top. But there are limits.
I'm somewhat familiar with the issues of edge rolling and diving when working with wood. I often make wind spirals which can cause edge rolling.
Getting acquainted by Pinnah, on Flickr
IME, you really need to match edge profile with the task. You have to get into upper end wood carving knives to get Rc levels higher than Opinel's. It is possible and if you go that route, 15-dps can be sustained but even still, lateral hogging is tough on the edge. I stick with 20-dps with the Opinel Inox and have good luck with it.
If any wedging DOES occur, the blade is narrow and the handle so round that it tends to twist on cuts unless a very firm grip is maintained - again something that my wife did NOT like and another reason i stopped using it for cardboard.
Tastes vary on round vs flat handles and lateral control under heavy cutting is an advantage to flatter handles. I generally flatten the sides of #10s for this reason.
But the issue you've encountered is the fact that you're box cutting with a teeny little #6. The #8 is the most popular for good reason. Try a #8 or, if you have XL sized hands, a #9 and you'll see a massive jump up in edge control with the larger handle. Or not. I'm not telling you what to do or not do. Honestly. Just noting that the problems you describe are related to the size of the Opinel you choose and that doesn't scale up to the larger ones. You would have the same problem with, say, a Case Peanut.
Finally, carving wood :thumbdn::thumbdn: When carving/whittling, holding the knife close to the cutting edge allows for a better transfer of force for clean, controlled cuts. Wood tends to bind and put lateral stress on a blade. The opinel is very thin so it cuts deep... and binds. Prying/twisting (part of carving) easily deform the apex and, holding from the handle of the knife, the blade often bends rather than proceeding with the task. In order to put more force behind the cutting edge, one must apply pressure to the spine of the knife where you are trying to make the cut, and the thin opinel blade-spine is quite uncomfortable in this.
My experience in working with wood is that blade thickness depends on the cut and the hardness of the wood. When the blade is too thin and the wood too hard, a thin flexible blade will bounce off the wood and either skip or dive or otherwise be hard to control.
Here's a wind spiral I did earlier this year out a some very hard (and nicely splaited) maple. My Opinel #8 just bounced off of this stuff and my (highly convexed) Mora handled it much better.
image by Pinnah, on Flickr
Is this the fault of the Opinel? <shrug> Match the tool to the job. Softer woods can be handle very nicely with thinner blades and if you put a convexed edge on the Opinel you will find it makes curling shavings wonderfully.
More than anything though, I think you were trying to push a tiny #6 too hard. The blade is too thin (I find the #8 a bit too thin actually and prefer the beefier #9) and the handle too small for hard force. Not at all surprising the Opinel #6 performed the way it did for you but it really says nothing of what is capable with #8, 9 and 10.
That's my $0.02 No hate, just realism.
2 cents back at you. No hate, but I don't pushing a #6 hard and extrapolating to all Opinels is very realistic.
I know what you mean, I'm just saying it's a cheaply made knife and people like cheap. Actually I wouldn't be surprised to find a good schrade 3 bladed stockman for that price.
I just bought two Opinels for $10 each at a local knife shop yesterday. I saw a like new USA Schrade 304OT like you just mentioned for $15. I had $20 to spend at the moment and I wanted a project. It was a tough decision. I wanted a project so I went Opie. The Opinel stainless is as or almost as good as that Schrade 1095.
I did say old knives were the best.
(I might go back for the Schrade)
Hey, diffrent strokes for diffrent folks.
For as long as I can remember they have been selling those Chinese nascar, wolf & John Deere knives as well. They are still around because people like cheap crap. People's affinity for cheap junk is what stands the test of time.
"They"? Ah yes, the infamous "they" again.
Yeah but you will look silly pulling an unsheathed steak knife from your pocket to cut your apple
Yup "they"....They exist and are buying cheap knives, you can go to any flea market and see them.
And the "they" that "have been selling those Chinese nascar, wolf & John Deere knives as well"?
Again, a forced comparison so intellectually dishonest. The only place I see Opinels for sale here are by a vendor selling Ganfors, Lionsteel, Benchmade, Helle, Zero Tolerance, Spyderco, Fallkniven, etc.
We're just repeating ourselves. Let's just leave it and let it suffice that I'll use my Opinel while you attempt to trash it. Matters not one way or the other.
We're just repeating ourselves. Let's just leave it let it suffice that I'll use my Opinel while you attempt to trash it. Matters not one way or the other.
Only calling a spade a spade. You can justify it however you want. People like cheap knives and that's why knives like the opine sell. Plenty of other similar quality knives for similar money. Have a nice day :D
Has anybody really handled a $10 modern folder as of late? They are named things like Night Force and Hunt Master. A guy at my last employer brought me a lockback he has gotten at a local flea market for around $12. The handle wasn't even Zytel, it felt like regular plastic with rubber sticker inserts. I knew they were stickers because the glue was exposed at the edges. The mystery steel blade was ground so bad that it almost looked like a chisel grind and the edge must have been finished on a grinder. The worst part? The lock wouldn't engage at all. A brand new knife some people here are comparing to the Opinel came like that. I took it apart and bent the lock bar, which looked like a piece of wire so that the lock would engage with an uninspiring soft click. Yeah, I will take the cheap Opinel any day over that garbage.
THANK YOU for replying. All this, "Opinels are the best! Everything about them is great! Try one, you won't be disappointed!" I did, I was, very much so because i believed the hype. It's not about them being "finicky and crude", it's that they lack a lot of what makes more expensive knives more expensive. That isn't to say that there aren't worse knives that cost more. But i am not cutting concrete and car-doors with a knife this size, i am cutting cardboard and wood and weeds, etc. In my experience, an Opinel is as much worth what you pay (~$15) as the Benchmades I own (~$80, and some of those required a little tweaking to be where i wanted them, no problem).
The knife is for my wife with small hands and she didn't want too long of a blade, the #6 was under 3", the #8 was too large.
I'm fine with tuning a knife. But the Opinel needs tuning and re-tuning and re-tuning... I checked the knife again, pivot is swollen and so tight that it can only be opened with difficulty, I'll need to take the heat-gun to it again. Also, the collar seems to be loaded with sand & dirt. Did i mention that I live on a homestead (think small farmer, like a peasant's plot)? My wife has been trying to put the knife to use as intended. I'm going to need to take it apart to get it working properly again. Time is money, and this knife will end up costing me MORE than an $80 Benchmade. Oh well.
I have Bucks & Gerbers in 420HC and Cold Steels Aus-8 at the same hardness, and not only do those edges withstand the lateral stresses of cutting roots and whittling wood, they seem to provide more edge-retention in cutting cardboard and rope, and they all sharpen with equal ease to a crisp shaving edge. The difference i can measure is that the Opinel is ~0.010" where the others are ~0.020", all 15-dps (same angle as my chainsaw, chipper, and lawnmower blades). The extra thickness behind the edge grants 8X more stiffness than the Opinel provides. It simply cannot compete.
I will do that.
It's great how light it is. My Benchmade "mini" knives are a little heavier but the same size, one-hand open and close, very quick and user friendly, MUCH more ergonomic, MUCH less fiddly, MUCH more reliable, MUCH more durable, MUCH better edge retention, etc. etc. and well they should be, they cost 5-6X more (this was before the price-hike, but you can still get cheap used ones).
Too big for my wife, too big for me to take out of the country and into the city. Even in the Midwest city near my home, ANY blade that large frightens folk, they don't know the difference between an Opinel and any other knife. These folk are scared of 2" blades! For the city, the easier i can retrieve, deploy, use, close and re-store, the better. Opinels don't offer that. For the country, I like a larger blade but the same principles of easy use apply.
With respect to pocket carry... At a mere 3.5" and 1.2 oz, there just isn't a more comfortable non-clipped pocket knife than the Opinel #6. I really can't imagine what you would possibly want more in a pocket knife in terms of comfort. The only thing I can think is that you and your wife are used to pocket clips and at this point, nothing other than pocket clip will satisfy you. That's not the fault of the Opinel.
My pants seem to have either deep pockets or tight pockets or both, and my wife often does not have pocket at all but may carry a small satchel (not a purse). An opinel or other non-clipped knife sinks to the bottom, hard to get at when needed, and in my pants it always lays on it's side, which can be uncomfortable as i change positions. I bought a clip-on sheath for such knives to improve carry. I don't blame Opinel at all, again it is a cheap knife. Some folk take the time and effort ($$) to give them clips, perhaps also recognizing the practicality of it. Most of the time, I'll just start with a clipped knife.
The convex is very low, just adds a little stiffness to the thin blade. Give me a taller blade that is thicker at the spine and FFG, that is a strong knife with good blade geometry.
15-DPS has long been the standard edge-geometry for such tasks in such steels. I have since raised the angle to 20-25 DPS and experience less edge-deformation on wood.
Not in my experience.
:thumbup: Its an advantage in ANY cutting. When i perform surgeries - VERY light cutting of very soft materials - I prefer a handle with less circularity. It's not the 'flatness' but the ratio of width to thickness. Round handles are more prone to undesirable twisting in ANY type of cutting.
Box-cutting was only one task, and I hoped the Opinel would excel being so thin. Yes, the short handle was a problem for applying more force, but it was the roundness of the handle that hampered control and the poor edge-retention and thin spine that really made it suffer. Again, blades 2X thicker behind the edge and much thicker at the spine had better edge-retention because of the steels and better control because the handles and blades where easier to control. If they took more effort to cut at first, it wasn't really noticeable. What WAS noticeable was that they cut more cardboard with greater ease.
My experience in working with wood is that blade thickness depends on the cut and the hardness of the wood. When the blade is too thin and the wood too hard, a thin flexible blade will bounce off the wood and either skip or dive or otherwise be hard to control... Match the tool to the job.
:thumbup: Wouldn't be a problem if one could apply pressure directly on the spine during the cut, but that doesn't work well with an Opinel.
Again, thank you for the sincere reply. And you are correct, the larger Opinels might work better than the #6 in some of these tasks. One day I may try one. But then I'll have to explain to my wife why i need to spend another $15 on a knife if i know that my more expensive knives get the job done well and don't know that this new Opinel will perform any better than the last one which was of comparable size to my EDCs. *shrug* As a 'starter' knife, I wouldn't dissuade a person from buying an Opinel, or as an alternative to, say, a Medford giant. But I would caution people to NOT expect too much. Realism, that's all.
Odd. I use my Opinel more than my (truly) custom Tom Mayo. Both are great knives for what they are. C'est la vie.
I haven't read the thread, but they're not for me.
Don't care for them at all, but if I was knifeless and only had $15 to my name I may buy one.
I never claimed they were the end all be all knife they just work better in their price range than the modern disposable cheap gas station knife.
I don't recall anyone ever comparing about losing their $10 jar knife but I can recall many who have lost an Opinel and even at $12-$15 and easily replaced, they still complained.
It's just a good working knife and if you've tried one and it's not for you than its not for you in not trying to convert anyone. :) just putting my opinion as per the OP's op.
You know quality knives. Quality steel, and heat treat. You have used thin customs, with super steels, in high hardness.
If the knife was made in Pakistan, with the same atributes (meaning they had the same steel, and were built the same), I would buy them. They would be even cheaper. If they made them in China, the same way, I'd have no trouble.
I have knives from Twain. China. Japan. USA. France. Germany. El Salvador. And a few other random places. All fine knives.
I am not an origin snob. I still like basic steels. Tool steels, carbon steel, even lowly medium carbon steels are fine if they are ground right, and heat treated right.
They are not "fine knives" from a finish standpoint. They are not customs, or high end production, or anything. Again, they are $13 or less. I could not care less where they are made. The fact that they are an original design, made in France is fine with me. I know junk when I hold it, or use it, and of the 8 Opinel I have owned and used, none were junk (that latest new Buck sure the hell was, though, truly abysmal construction and fit, though it costs 3 times as much). Was it less of a gas station knife because it as made in the US, and was more expensive? I have used $6 Chinese knives with way better quality.
I can't think of a knife that I have used that cuts better at any where near even 6 times the cost.
I like them enough to want more in the INOX and in different woods.
No one is trying to say that a $13 dollar knife is better than a Phil Wilson laser slicer in super duper uber steel at near 70rc.
I still have Busse and Swamprat. I still have production folders, modern and traditional, and a few customs. I have used a few knives that cut better. Held an edge longer. I have a custom knife with a secondary blade that will cut better, and hold and edge longer. I could purchase about 46 Opinel for the price it cost to have that custom knife built. I don't need 46 Opinel, and I really love that custom.
The enjoyment of one does not diminish the other for me.
Yeah, that's reasonable and realistic. :) :thumbup:
Now if the other posts in this thread were more inline with this one instead of making them sound like magic and the best knife on the planet.......... ;)
Isn't it great how everyone can embrace what people do enjoy, or don't. Without the addition of derogatory comments?
Don't have any soddies left. One Case Sodbuster Junior lost, and another Jr. as well as a GEC Bull Nose given away, but I still have my Opinel No. 8 all these decades later.
Everyone's entitled to their opinion, and of course the Opinel isn't for everyone.
Sometimes the superlatives get a little thick, but that happens all the time. People just often talk (and write) that way nowadays. I don't think the majority of the posts in this thread were overly gushy though, and really, is there that much harm in hyping a $10 knife? In the wide, wide world of overhyped products, the lowly Opinel barely registers on the scale, imo.
What is disappointing to me is seeing one of the most respected posters on the forums, a guy whose stuff I sought out and read for years, devolving into some weird gas station knife troll guy:
"Pffft, :thumbdn:, lulz, cheep cheep :rolleyes: *cough* garbage *cough*, gas station, POS, Europe :barf:..."
Would that about sum it up, Jim? Feel free to copy/paste the above in the future if it will save you some time :)
Really, I just don't get it.
It's super cheap but still gets the job done... GREAT!
It's made by a family run company with over a hundred years of history and is a known quantity instead of some mystery brand, with mystery steel, which may or may not be made with slave/child labor... GREAT!
Personally I like reality and if you have read my posts etc over the years you already know that..... ;)
The bottom line here is they are a $13 knife give or take and they are what they are, yeah they have a following like some other knives in the same price range.
Yeah people use them and have for awhile, but knives in that price range are throw a ways, beaters etc and that's fine... Nobody is saying that it's not....
The problem comes in when people hype things up to be more than they really are........ That's when my BS alarm goes off.......
Yeah I understand people like cheap stuff and a lot of them will try to make cheap things sound like they are much more than they really are...... That's the problem...... ;)
