- Feb 6, 2012
Also, there was a post from a forum member here a few months back about him slipping from a roof and as he slid towards the edge of the roof he stabbed (in reverse grip with edge facing away) his Griptilian into the roof and it held his weight and possibly saved his life.
If knife "X" fails a spinewhack test does that mean it would fail in a situation like the one described above? The difference being an abrupt, jarring strike (spinewhack) versus a (relatively) slower loading of the lock.
The spine whack is as valid in testing lock strength -- or at least one particular aspect of lock strength -- as any other method. Also, in the scenario you describe above, pressure is exerted on the knife is in the opposite direction to that tested by spine whacks. Had this member stabbed the blade, edge inwards, into the roofing as he fell, the knife may have closed on him. That would have certainly changed things. Remember, folding knives are fundamentally stronger when pressed against the edge (and into the stop bar or similar stopping mechanism) than they are when pressure is applied downwards from the spine. Accidents happen, and it's awfully nice to know if your knife -- and your fingers! -- will stand up to an errant blow on the top of your blade.
