In a word Spyder-drop.
I sold my paramilitary for that very issue. I just couldn't get used to tip down.
The Military was designed to be carried/used while wearing gloves, as such it requires a significant portion of the handle to be above the line of the pocket when carried clipped.
If the clip was tip-up the knife would require re-situating in the hand to deploy and would not be as secure upon the opening sequence. If the clip were reversible there would have to be two pocket clips included with every knife since the clip is side specific and cannot just be flipped to the different side.
Combine this with the fact that the liners on the Military are only partial and, when first designed and produced the knife only had one liner and you get a tip down, right hand only design.
Para is 2/3rds version so I assume the clip was retained for the same reason.
As I understand it the Para and Millie 2 are supposed to be 4-way clips.
