bodog
BANNED
- Dec 15, 2013
Aside from aesthetics, why is there so much emphasis on buying a strop? Most of the time a compound is applied and that means almost anything can be used. I've used a piece of notebook paper and gotten great results though it wasn't very durable. Normally I use some thin cardboard, the kind that comes in new button shirts. I cut them up into two to three inch by about 8 inch strips, apply compound, and go to work. I spend no money on my strops aside from the compound itself. I use a flat piece of wood as a backing. If I want to I can make smaller strops and carry them in my wallet if I wanted to. I could use an old belt. I can cut up a pair of jeans and wrap it around the same piece of wood. I find the cardboard is the best, though. I use it until the paste is completely black and simply throw it away and make a new one which takes all of about 1 minute.
I can have strops running from 1000 grit up to 100,000 grit for just the price of the compound. Why spend 20 to 30 bucks per strop? They're easier to store, cheaper, and at least as effective. I normally run up to 14,000 grit and finish with simicrome and get mirror finished edges, although they could obviously be finished at a higher grit. The cardboard is already flat which leads to accurate bevels with no apex rounding.
So, I get really good results from my strops. Is there really any reason to spend so much money to buy a strop from someone else? I'm really curious. It doesn't make sense to me.
