So I tried this the other day, and I think it worked. For clarification though, do you strop the knife at an elevated angle (single trailing passes) to deburr or do you do the sharpening motion (up and down, pressure on the trailing strokes, maintaining consistent angle but in my case elevated for debuting) to deburr?
Can you start the 1000-grit alternating passes when you feel the edge and the burr is gone, or is there some other way to decide when you're done with the elevated-angle deburring?
I wasn't very clear was I. I'll make sure to read my own posts before hitting the button next time.
The deburring passes are not stropping motions. They are edge leading motions, like cutting into the stone. Very light pressure and at an elevated angle should cut the burr off in as few as one pass per side, but may take 3 or 4 per side. More than that and you will make a new visible bevel. You can feel the burr if it's still there by stropping the blade lightly on your arm or the back of your head. It will pull a little if it's still there significantly.
These small number of edge leading passes will make a tiny new bevel, even if you can't see it. Going back and alternating passes at the original angle will get rid of it. This should take maybe 10 passes per side or maybe a few more if the bevel is very wide.
Then go to the 6000 side and use edge leading alternating passes at a slightly elevated angle. This will polish the edge and refine it. The 6k stone might be too soft for edge leading passes. The edge will dig into the stone sometimes. In that case, use as light a pressure as you can manage for the edge leading strokes, but limit them to 10 per side or so. After that you may have to use a stropping motion on the 6k stone. Use as few passes as possible and check sharpness after each back and forth pair of passes. Once its sharp to your liking, stop. My 4k grit stone is pretty soft and I sometimes have to use stropping motions to finish edges with it. Edge leading motions will dig into it if I'm not in top form and paying attention. Edge leading will give me slightly sharper edges, but edge trailing for the last 2 or 3 passes per side is much more forgiving of sloppiness on my part.
For very stubborn burrs, I use a slightly different procedure, but it's usually not necessary. It's an extra step and takes longer overall. If it doesn't work let us know and I'll post the alternative process. When I say stubborn, I mean on very gummy/soft stainless steel, unhardened steel, or mild steel. Yes I've made and tested knives from annealed steel without heat treating them. It was a dark time in the mid 2000s.
