NeedleRemorse said:If you were out in the woods and had to cut a three-inch-in-diameter sapling, would you rather use a Swiss Army Knife with a saw or a 7" chopper? I for one would take the saw for two reasons: A) the cut is cleaner and more precise and because of this and the smaller motions it B) wastes much less energy and time.
I would prefer the chopper, since the saws on SAK's are just about useless- I have used both Vic and Wenger saws, and on anything over two inches they dont work real well. The saw doesnt lock, and is so short that on a three inch Diameter sapling you cant get any saw motion in. It also wants to close on my fingers.
NeedleRemorse said:If anything, I find the SAK saws to be very aggressive and I don't cut with the spine so I guess I've never needed a lock (on any knife). I do agree the a smaller sapling would be a better example, but even on things with a larger diameter than the length of the blade I have no problem using the saw.
Thirteenth Star said:...the tree's weight will push down on an axe and create a great deal of downward force that tends to seize a saw at the end of a stroke.
I cut down a tree recently (without the help of "undocumented immigrants", thank you very much) and I used an axe instead of a saw. The reason is that, in the case of a large tree, the tree's weight will push down on an axe and create a great deal of downward force that tends to seize a saw at the end of a stroke.
knifetester said:They require much less energy and concentraion to use.
OwenM said:Now take a 8" log ...
