- Jul 20, 2021
Once a microbevel is created: is it still a scandi grind?
I agree a micro-bevel can make a scandi-grind survive a bit longer and make touch-ups faster.You don't have to sharpen it this way. In fact I think it is more common for scandi knife users to lift the blade a little when doing touch ups so that you hit the apex and create a little microbevel. This method was also descriped(and pictured) in the small booklets that came with my Helle knives when I bought them years ago. I don't know if they still do though.
A lot of scadi grinded blades comes from factory with a miocrobevel already on there.
Maintaining the scandi grind, sharpening the whole bevel, is just something you need to do once in a while to maintain the grind.
Off course some guys swear to maintain the true scandi and go over the full bevel every time, but IMO this is just not necessary.
That's false.You actually have to remove a LOT more material to sharpen a scandi, as you have to remove material along that whole fat bevel.
Or you could skip all the stupid math crap, ditch your scandi blades and enjoy completing your task with any other knife you want just as easily and probably better.That's false.
Here's a procedure where you have to remove more blade material to sharpen an FFG.
1. Get an FFG knife with only these 2 grinds. The FFG is 10 degrees. The ege is 40 degrees.
2. Where the grinds intersect, measure the blade thickness (x).
3. Find a scandi knife with one grind (a 40 degree edge) and a thickness less than x.
4. Dull both knives.
5. Sharpen only the primary edge on both knives.
questions: Is it easier to sharpen a Scandi or an FFG? Which sharpening removes more steel?
answers: Either or both.
If you only sharpen a primary edge on an FFG, you will eventually get a fat edge. Sometimes sharpening involves grinding the whole FFG.
Popular construction knives seem to all be scandi. The types I know of are utility, snap-off, and chisel.
Carbide teeth on a circular saw blade and face mill inserts look scandi.
An AD-10 with a scandi grind would be the best knife ever, hands down. The knife world would explode if such a thing existed.BECAUSE IT'S THE BEST!Please pay attention. Vegetables actually slice themselves when they see a scandi coming. Fruit is a different matter, very rebellious.
Here are the thinnest scandi blades I've seen. A double edge razor is 0.1 mm (0.004 inches). A 9mm snap-off knife is 0.381 mm (0.015 in). A surgical scalpel is 0.4 mm.Scandi grinds are for Bushcraft. They are thick behind the edge
Maybe. My Mora Eldris came with a micro bevel. If Mora adds one, I'm thinking it must be legit.Once a microbevel is created: is it still a scandi grind?
Have I missed something? In what universe is a scandi grind more practical for cutting food than a FFG?
Simply stating that its the best, which you already did, isn't a reason. Explain why you think that, and maybe someone will pay attention. Personally I find that when the fat part of the blade reaches the vegetable, resistance increases greatly. The peeled section of vegetable sometimes breaks off. A full flat grind seems to penetrate through the vegetable more easily. I often take my Mora Companion camping, and use it for food prep, but that is because it was dirt cheap, and easy to keep clean in the field, not because it actually cuts better.BECAUSE IT'S THE BEST!Please pay attention. Vegetables actually slice themselves when they see a scandi coming. Fruit is a different matter, very rebellious.
