Why do some knifemakers file or sand the edges of their contact wheels Do a lot of knifemakers do this? What does it accomplish and how do you do it properly if you should do it at all?: Larry
Some makers put a small radius on the corners of their wheels to give a little more radius to their plunge line. I'm not sure of the best way of doing this, I only know that I've accidentally done it to mine and need to true it up. hahah
You can also "break in" a stiff belt a little with some scrap steel, run it over the edge and work it a bit to soften it for the radius. Or use a flexible belt like a J-Flex for that.
