It seems 1 in 3 threads lately have been asking what production folders are the strongest? People say they want a folder that can handle anything and everything. I do not understand why you want a knife so thick that it diminishes it's cutting ability, because you may have to pry with it someday.
So-Lo said:
I also don't understand why people talk about locks so much. I cut with the edge 100% of the time, are they cutting with the spine?
There's a couple reasons for the above. The first, and best, reason is "they wanna". Same reason I have 4 bows, several dozen guns, kukris and a couple of swords. I'm way beyond "need".
Another reason is some people live in communist states/cities that severely restrict your carrying cutlery. In which case their folder is their only defensive piece. You never know which way you're going to be twisting the knife in a fight, and may indeed be putting a lot of side load on it, and need a stout blade. Also the reason you need a good lock. You don't want to stab the guy who's trying to kill you, have the point bury itself in a rib, and have the damn blade fold on you and cut your fingers off.
Some other "reasons" are the very common incidence is guys who go woodshopping with backs, hips and ankles that can't stand up to another 3/4 pounds of weight of a larger knife to do the heavy work, or God forbid, 2 pounds of hatchet.
Then there's ergonomics. I like the Ka-Bar Mule, not because it has a giant blade (it doesn't, the blade is thinner than you might think, and is short enough to be under the legal limit in communist areas), but because it has a comfortable grip for real sized hands. Many of the folders guys recommend have thin, slab-sides grips that, while they make it easier to carry in pocket and conceal, just flat suck for use.
