- Oct 23, 2010
My 220 cuts like crazy, but I swear the 120 hardly cuts at all. It feels about the same as the 1000. Why is that? I can't even use it because it hardly does anything to the blade.
Put some playground sand on a piece of concrete and rub the 120 on it for 30 seconds to a minute. It just needs coarse lapping. Carbide grit on glass works a lot better, but the first way is something you can do right now.
Thanks. Is there a reason it came so smooth? To the touch it feels no different than the 1000 grit stone, while the 220 feels very rough.
OR it's defective like quite a lot of use received theirs.
a couple forumite had the same issue and nothing made the stone cut including free SiC powder, 40 grit SiC paper, 120 grit dmt ... the stone just doesn't wear at all no matter how hard you try. if it's the case contact ben dale.
Ben Dale won't acknowledge the problem.
I've called Mr. Dale numerous times with questions. I've never had him fail to acknowledge , or correct a problem, or to use as much of his valuable time as necessary giving me sharpening lessons over the telephone.
Ben Dale is one of a dying, and unfortunately rare, breed. A true GENTLEMAN!:thumbup::thumbup::thumbup:
So what does he say about this problem? He stopped answering my emails after he told me to lap my 120 stones and I did and they cut just a little bit better but still way slow.
I've never heard of this and don't seem to have that problem with mine.
Uploaded with ImageShack.us[/URL]It seems that the slow cutting problems are associated with the newer bluish tinted Edge Pro stones(see lower stone). The older ones that are grayish don't seem to have these problems(upper stone).
[URL=http://img522.imageshack.us/i/edgeporstone120.jpg/]Uploaded with ImageShack.us[/URL]
My stone is definitely the blueish one on the bottom.
So I have a defective stone?
So my 120 might just NEVER cut? I rubbed it on the concrete outside and it might be a LITTLE rougher, but not much at all. It's still very smooth and cuts very, very slowly.
Did you use sand? that is very important. Concrete alone, even broom finished, won't work. Smooth concrete and good sand are what you are after.
This is the first time I've heard an EP product doesn't work, or that Ben Dale didn't bend over backwards to please or help a customer.
