- Mar 8, 2008
Ceramic stone. Spyderco Ultra Fine Triangle.
Allow me to give you a forzample :
My brand new Case Trapper in Chrome Vanadium (CV) = basically high carbon steel that will rust; not particularly hard. A couple of days ago I sharpened it on the Edge Pro = sharpened it right for the first time. I took the bevel angle back some; not particularly shallow but some. Did a halfast polish on it to Shapton Glass 4000. Whittling.
Used it at work the last two days. Came home to night to find the edge had rolled some.
I pulled out the ceramic UF triangle rod and took the roll off and got a bur. Going edge leading I just could not get the bur off and did not want to go steeper (that would probably have took it off).
I whipped out my little chunk of USA made Norton 8,000 water stone (new ones are made in Mexico now).
In no time I had taken off the bur effortlessly and the knife was whittling again. Seemed to be a touch better edge than off the Edge Pro using the Shapton Glass.
If I had stuck with the ceramic rod FOR THIS STEEL I would still be there flipping that bur back and forth even though I was going edge leading. For other steel alloys the bur would have formed and soon would have come off and I would have stopped there.
Just depends.
I will say I love that Norton 8000 though.
I find the Ceramic triangle very useful most of the time.
PS: before I started the ceramic rod was very clean from using cleanser on it before putting it away from the previous session.
Don't use the ceramic for removing a rolled edge. Use it for a few light strokes on either side after removing the edge damage on other stones. If you were to use it after the Norton you'd probably get good results. It would be most accurate to refer to them as hones rather than "sharpening stones".
