...FRN also needs a stiff backer, which is why you almost always see it used on cheap liner locks.
Actually, there aren't all that many high tech plastics used for knife grips. Most are used as scales over a supporting metal insert, like Delrin on slipjoints. Fiberglass reinforced nylon isn't anything like G10, simply because it's injection molded. G10 is laminated and cured as sheets, which then require further processing. It's much closer to Micarta, and when shaped, has a similar layered look. FRN just goes fuzzy. FRN also needs a stiff backer, which is why you almost always see it used on cheap liner locks. The stainless steel liners are required to prevent the scales collapsing against the blade and trapping it when clipped in the pocket. Integrally molded clips will also loosen and the knife will fall out - which is why you no longer see those on quality knives like Spyderco.
G10 is stiff enough to need no liners, and expensive enough to shape that it isn't found on cheap junk knives. Because the labor to work it drives up the price, a decent steel is used, and you automatically get a superior knife compared to all the FRN junk flooding the market from the four corners of the earth. You also get construction techniques that can't shortcut a quality build.
All told, a G10 knife usually stands head and shoulders above the pack of FRN curs barking for your attention.
(I'm not sure of the difference in -10 & -11)
Ive wondered that as well. Is there any difference other then chemical?
Could be flame resistance. I thought G-11 was the natural (i.e., slightly translucent) colored stuff.
What is so good about G10? As far as I can see, it's plastic and is not better than Aluminum. Why do so many makers use it? What are the advantages over Aluminum?
Are there any benefits as insofar as knives are concerned? I look for a lot of things when choosing a blade flame resistance isnt one of them. Or maybe it should be![]()
I don't have anything in G10 yet, I would think it's brittle. Is it?
