- Aug 24, 2017
I tried an experiment last week. I profiled a blade and immediately heat treated and tempered it. I polished the edges and the flats with 320/600 grit belts. I would have gone farther if I had higher belt grits. The 600 grit belt left the blade shiny, almost mirrored, but with streaks, I hand sanded with 1000 grit paper, but decided that it looked better after the 600 grit belt.
After getting the flats to what I was going to consider finished for this experiment, I ground the bevels with a 320 grit belt. By finishing the flats before grinding the bevels, the grind lines and plunge lines remained sharp and crisp. The results were better than anything else I have done (I've been making blades for two years) and I think you would find the blade to be acceptable in every way. I don't think that I spent more time at the grinder because of the high grit. The steel came off the blade quickly. I only touched the bevels one time in the process. The aluminum oxide abrasive doesn't seem to be phased by hardened steel.
The conventional process begins before hardening, with belts containing grit you could use to pave your driveway. I am wondering if there is a good reason to start coarse, before heat treating, going up to finer grits in stages before and after HT.
I am using an Origin Blademaker Grinder with a 1 hp motor and Combat Abrasives aluminum oxide belts. I use jigs for grinding flats and bevels.
What am I missing?
What am I missing?
