"Why have I not seen Axis vs. Pinnacle posts?"
Well, looks like you just made one;-)
The only things that the MonoLock and the Axis-Lock really have in common is that they are both from Benchmade and make us of the same blade material.
Although they are different in design, I suppose they can be compared as to which would suit you better for certain tasks, let's give that a whirl.
Axis-Lock: Every new lock has a first model it is used in, it is in good fortune that the Axis-Lock has such fantastic company this first time off the blackboard. The Axis-Lock is very comfortable, entirely pleasing to look at (you will notice that the curve of both ends of the blade continue to the handle with nobumps, completely seemless), and lends itself to some very utilitarian tasks very well. This knife isn't a fighting knife, but it could be said it also isn't a utility knife. It can be held, at least in my hand, in every position comfortably and easily. The fit and finish of the handle is very good, the G-10 is refined at the edges and has a very good medium grit texure. The lock is, well, it's as close to perfect as I think I am going to see in a long time. It is magnificent, my fingers steer clear of the blade at all times while closing, and the strength is evident when the lock engages for the very first time: This is a seriously strong design and is very easy to use. A true winner.
The MonoLock is a very good knife as well, but I think that it does emplo some design flaws that make it a bad choice for my personal use; The choice as to if it wil be good for YOU is, as always, in the end left up to you.
The handle is not a very comfortable one, the lines are somewhat bulky and I do not like how the traps my comfortable handling choices to only the hammer grip. I am not pleased with that fact, it alone makes the knife a bad choice for me in my book. You will need to hold one yourself to see if it is right for you. The lock is damn strong, it really does stick quite a bit, but I have never seen the need for a fast closing knife, once I open a knife I am going to be using it is going to stay opened for a little while... Fast losing isn;t a concern in my book, it can be one hand or two for all I care.
All in all, I would say the Axis-Lock is the real winner here, it took the lime light away from the Mono-Lock for a reason you know... It's more revolutionary, that is a given. But, in my opinion, it really is just plain better.
Robert Joseph Ansbro
If it can be written, or thought, it can be filmed. -Stanley Kubrick, 1928-1999
www.Cinematopia.com
I am the moderator on the forum "The Balcony" located at Cinematopia, please come support this brand new site
