- Oct 3, 1998
Why I Like Clips
by David Rock
Experience and observation teach me that a knife spends A LOT more time in my pocket than it does in my hand. Consequently, I'm willing to sacrifice a bit of hand comfort for the sake of greater pocket comfort and convenience.
In addidition to the added convenience in carrying a knife, I have also found that in some instances a pocket clip actually improves grip.
Case in point: I have here in my left front pocket a Spyderco Delica, '98 version. The clip is removeable, currently set up for a lefty. The handle on this knife is rather thin. The clip provides extra width and a convenient ridge for me to anchor my fingertips against when deploying the blade. Now, let's see what happens if I remove the clip (all it takes is a coin and a few seconds; what a great design--kudos to Sal Glesser and the folks at Spyderco). Okay, the clip has been removed. The knife definitely feels thinner in my hand, but I can get used to that easily enough. Hmmm. I'm noticing that the knife wants to rotate in my hand more than it did before. The clip seems to have improved stability. Let me try opening and closing the knife a few times. Whoa! There's not much to hang onto here. My fingertips tend to slide off the edge of the handle! Smooth Zytel on dry skin doesn't generate very much friction. The force required to push the blade open is sufficient to pull the handle out from under my fingertips, if I'm not careful. Perhaps I'd learn to compensate for this after a while. As it stands right now, I'm noticing that my fingers, in order to gain adequate purchase on the edge of the handle, must press harder and remain closer to the blade. If I use the thumb hole to CLOSE the blade, or if the blade should accidentally close on me before it locks open, my fingertips are very close to the danger zone where the blade fits between the handle slabs. In a situation such as this, I definitely like having the clip as an anchor point for my fingers.
In all fairness, I have done extensive testing on this Delica, on one occasion whittling a hardwood dowel for nearly an hour at a sitting. I will admit that the clip did tend to bite into my hand somewhat after a while. It became uncomfortable, but not exactly painful. This is a compromise I'm perfectly willing to make. After all, how often do I use a folding knife hard for an extended period of time? Almost never.
All things considered, I'm leaving the clip on this knife, even though I generally carry it loose, down inside my pocket. It seems to make the knife work better in ways that are consistent with how I intend to use it.
Regards to all,
D.R.
by David Rock
Regards to all,
D.R.
