- Aug 31, 2011
That's what I use I order them in packs of ten.Or a F letter bit...
Also metric you can do about 6.4mm to 6.6mm
For tangs I use a 9/32" bit, and for the handle material I use the F letter bit. I am pretty sure a 6.6mm will also work for handle materials.Why!??
There are fractional drills, Metric drills, Letter drills, and Number drills.Oh my gosh I hadn't even heard of that. I actually thought you were implying a cuss word
Okay thank you I will look into all of these. Appreciate you guys!!
No reason for life to be simpleThere are fractional drills, Metric drills, Letter drills, and Number drills.
If it was easy, somebody else would be doing it!No reason for life to be simple
For years I had no issue with 1/4 inch bit for 1/4 tubing but then something changed.
yes indeed and what you don't have at least 1 set of each ????There are fractional drills, Metric drills, Letter drills, and Number drills.
hell i got 2-3 of some (im over prepared)
That's a good Idea,ok fine
since this is something that will Never stop being a issue for you guys .... Make them from a Reamer !!!!
every size is available in either HSS or Carbide.... you make a collar/drill stop and cut the tip down to whatever size you need it
then you re sharpen the tip so it cuts flat... total time 15/30 minutes.......... 15min HSS -30 min Carbide
ive been doing this for 25 years instead of counting on any supplier.... i cant believe no one else does this !!!!!
F letter bits on the way.These will save so much time in the shop. To think I just assumed everyone had to chuck up their pin stock in the drill and run it back and forth on the belt...
