- Sep 20, 2015
Usually I call it the extraneous thing that is in the way of gripping my knife properly.
However
since someone pointed out what a good peanut butter spreader / sandwich blade it is I did not remove it from my latest trapper.
The other day I needed to transfer grease from a large bucket to a work bench grease pot and used the blade. Worked perfectly. I had a hard time getting the entire film off the blade once I got home though. Used DEP citrus degreaser, rinsed, used dish soap, rinsed, used Boraxo grit hand cleaner and rinsed . . . there was still some haze of grease traces here and there. Gee . . . good grease ! Next time I will go straight for the WD-40 or paint thinner.
So . . . for now . . . the speyay(de) blade remain in situ.
What is the reason for the roundy end ? Is that so once you do the dirty deed and the animal starts to try to kill you for it you don't accidentally stab it ? Just curious . . . since the Vets blade is a different shape.
However
An actual surgical blade for speying operations by veterinarians on female animals would be a completely different profile, I would think.
