Gollnick
Musical Director
- Mar 22, 1999
Thomason said:A strong resemblance to Richard Nixon. Wasn't his middle name Militec?
No, no! It's John Paul II! I recognize the hat! It's a miracle! Sainthood NOW!
Well, that explains a lot...Gollnick said:You went to MY website looking for sober minds?
He obviously doesn't know me very well.![]()
fulloflead said:I just basted two balisongs. They're in the oven. 250°
fulloflead said:250° is too hot! When I dripped some water on the blades it sizzled but didn't completely evaporate. They were at that temperature for about 30 minutes. I hope I didn't ruin the temper.
Gollnick?![]()
Gollnick said:250 should be fine. The problem with household ovens is that they're not well-controlled. An oven set for 250 can easily hit 300 and now we're starting to get close to danger territory. But, even then, the temper of most knives is not affected until you exceed about 350.
My guess is your safe.
I suggest the drop-of-water test because if a drop of water on the blade doesn't sizzer at all, you know the blade is well below about 250 which gives you a hundred-degree safety margin.
The other reason I suggest the drop-of-water test is that it's so simple. It's simple to understand because most everyone knows that water boils around 212F. And it's simple do to because it doesn't require any special materials or equipment or any exotic technique, just a drop of water.
What part of this did you not understand? Were you drinking and surfing?fulloflead said:Ya know. There seems to be some discrepency on how to use this stuff and I can understand why. While reading their website I repeatedly made the following exclamation, "You want me to do WHAT?" They want me to stick my gun under a black tarp in the sun? (See what happens when you eat the worm?)
AKA Knife Knut said:What part of this did you not understand? Were you drinking and surfing?
AKA Knife Knut said:As for the "booger"
Either it is a loose piece of plastic swarf that was not removed when the bottle was made,
OR
it really is booger, but it is from Micheal Jackson's plastic nose!
