I would guess because the Zaan and 25 have adjustable blade tension and do not require a pivot bushing, as opposed to the 21 which does use a pivot bushing and non-adjustable blade tension.
You're saying it like "adjustable blade tension" is some sort of a feature while the bushing pivot is just better in every possible way, if made properly. You always get the right tension and no locktite is needed. The only reason for having no bushing pivot I can see is that it's easier (and easier means faster and cheaper) to make. You don't need so much attention to detail - the knife is just assembled, no fine tuning of washers etc. is necessary.
On the Umnumzaan and possibly the 25 do you have to tighten each side of the pivot screws to help get centering correctly?
I guess every model will be different but you have to with mine. When I got it, the centering was slightly off to the right. It wouldn't be enough to consider if it was any ordinary knife. It's the type of issue that would be of concern to only perfectionists or those who tinker. But comparing to it to my 21 models, it is not as centered out of the box. When I cleaned and reassembled, I had to tighten it almost all the way to get it perfectly centered. Then it wouldn't open. It was like it was super-glued shut. I had to let up on the pivot a bit, which took it a tad out of center. It then opens fine.
To be fair, this does not effect the function of the knife. Operationally, having it slightly off center does not result in any operational issues and there is no blade play. But compared to the tolerance standards of the 21, it does fall short for me IMO. It lacks the precision and tolerances. I wish it had the bushing pivot. I don't dislike the knife, I just am a bit anal when I purchase something this expensive and had expected the same perfection I find on the 21. In terms of fit and finish, it really doesn't stand out from some of my other less expensive knives in my collection. I can't use the tolerances and engineering to justify the high price as it really isn't anything special in that regards compared to many other Titanium frame locks out there.IMO. First knife I have purchased that has to used loctite to keep screws from backing out and going off center. IMO, that is not a marvel of culinary engineering that CR is supposed to be known for. IMO, it's a $200 titanium framelock knife with an inflated price due to the name.
Don't confuse tolerancing with engineered design.
Tolerances are the deviation off of nominal that a part can be and still function as designed.
Here is an example. The pivot diameter is supposed to be .3125 diameter on the print, but for manufacturability, it usually has a high and a low dependent on function and fit desired.
.3125 dia +0.000 -0.0005
Of course the numbers given are an example only- They don't really apply to any part that CRK manufactures.
I just use the terms as an often stated opinion is that 'tolerances, fit, engineering, ' etc and the labor that goes with it is part of the justification for the high price. Having the knife, I can't think of any other reason than it has the CR name on it to equate to the $440 price. It is a nice looking knife and blade for sure and quite unique in that area. But it is outdone in the fit and finish dept by some of my other Titanium Frame locks at half the price--and they don't require tinkering to optimize opening vs centering and don't require loctite to keep things from going haywire. IMO, the 21 is superb all around but the Umnuumzaan is kind of a finicky plain Jane framelock knife with a custom price tag. Severely overpriced. Again, IMO.
That is fine- I understood where you are coming from, but wanted to clarify the difference.
As far as cost goes, that is always going to be a matter of opinion.. I have one and certainly do not find any of the things you have found to be objectionable.
My pivot takes no more time to "adjust" than a 21 does to tighten and I don't have any issues with it loosening up, so I am not sure where the time sink is with fiddling with it?![]()
My opinion is that you shouldn't have to fiddle with a $440 knife to get it aligned and also be able to open without a prybar. It came out of the box slightly off and when I got the blade perfectly centered, it just won't open. The pivot becomes too tight.
I know that's just my opinion and others see it different. But for me, on a $440 knife that is inexcusable, no matter how you look at it. On a $20 Chinese-made knife I would expect that.
Maybe your particular knife has a problem? I would send it in for warranty evaluation before blaming the design.
