I'm having the same issue with an Umnumzann that I got in the mail today. Used. But I noticed when I loosened one of the pivots the blade would not center. If I tighten it down, I can't open it. I'll pull it apart tonight and clean and lube to see if that will help. It's a Wilson Combat version from 2012. Very nice looking but need it to be more smooth. In addition to the difficulty opening it isn't super smooth opening. A bit "rough" if you know what I mean.
Extra lube definitely helped the situation with smoothness. But in terms of centering, I am unable to tighten it down to the point the blade is centered and I am still be able to open it. I experimented with the pivot screw and got it to the right point where it wasn't too far off from centered but was acceptable in terms of opening ease. But I had forgot to put any loctite on it..arghhh. Had to do it all over with the loctite. If you don't use it, the screw will back out enough to really throw the centering off after a short amount of time, at least with my model. Then blade play starts to be an issue if it goes too far off center.
At first I thought I had an issue with the washers being pinched. But they are flat--at least as far as I can tell. Everything fits together fine and no perceptible gaps anywhere. Maybe the washer are too thick/thin. I have no idea. Based on my searches online, enough people have brought this up though that it just isn't me. It seems to be hit or miss.
Which brings me back to the question I posed in the beginning before I went off on a tangent and complained. Why not just use the proven bushing ? I really don't understand why they didn't. This really is a nice knife outside of these issues. The blade design is awesome. I would like it better than my 21 if not for the issues.
