Handle and a half.
The handle is constructed of polypropylene, a lightweight thermoplastic polymer that is very resistant to acids, stiffness and fatigue. Despite the sound of it, the texture of the handle is well done, a modest wood grain feel that still holds, even when cutting a greasy turkey or washing the knife with soap in the sink. The shape of the handle has no odd edges, ridges or irrelevant nooks that are designed to "hold it" under slick conditions. All those crazy notches and grips I see on handles just seems to lead to blisters when I'm actually using the knife to do heavy carving for a long time. The fingers curl around the tapered handle for a very natural feel. The roach belly also has a handy lanyard hole that will fit paracord. The handle is approximately four inches long, a very good size for both small and large hands, and the taper accommodates it very well. The bottom of the handle is rounded, and proved itself handy for grinding up some finer tinder particles much like you would a mortar and pestle.
I was initially concerned about the joint where the finger hits the handle and the blade, but this worry proved to be superfluous after some heavy use. It would be good to point out that that little spot where the finger rubs on the blade isn’t sharp or ground at any angle, its smooth, something that you wouldn’t expect on any production knife. Even the spine didn’t have any 90 degree angles! Would it spark then? You bet, even with the smoother spine edges. Even the thumb grooves were well done, and didn’t abrade or agitate the thumb during push cuts in the cold.
Steel
The krupps stainless steel held up well to the elements, and didn’t rust or discolor at all in any of my day to day activities. The edge held up fantastic, the low Rockwell made it an ease to re-sharpen, and went from shaving sharp to scary sharp in a second on the ceramic rod that came with the Spyderco Sharpmaker. This knife was a breeze to re-sharpen, though it hardly needed it. I was very impressed and happy with the edge retention of this modest steel. As mentioned earlier, it even threw sparks on the spine. Now I don’t know much about 4116 Krupp Stainless, but I will say that it is a breeze to maintain, as apposed to other stainless steels, which raises more than a few eyebrows from the field aspect (think using rocks to re-sharpen). Though its not the rescue type knife, the sharp edge cut seatbelts very well, see the attached video
How does it ride?
The sheath is of the same material and construction as the Finn Bear of the same line (another great and noteworthy knife). It rides deep on the belt, and didn’t snag in the catbriers or the grape vines during excursions into brush. I love that feature in a sheath, knives that have a lot of handle sticking out seem to get caught on barb wire fences when I kneel to go through them. The sheath is expedient, and holds the knife securely. The webbing that makes up the large loop feels a bit substandard, and the nylon on the front of the sheath did abrade a bit while I wore it working on my vehicle.
