Cost? Because the blade is coated? That'd be my guess.
I figure the same reason the grind marks are still there under the coating - costs extra time and money for details like that. Easy enough fix for it though; only takes 5 mins or so with a file. I put a small crescent shaped divot on my 16 just before the jimping with a dremmel when I first got it. Worked great when I had the coating still on.
I squared the pommel on my bk2...throws sparks easily and didn't create a sharp spine where I put my thumb.
I guess some ppl just aren't happy with what they get no matter how much value for money a knife is.
What I meant mate was that most ppl buy beckers to mod them. They are already a very good value for money , so complaining they don't have a squared spine seems a bit much. That was all I meant .
I use the choil on my 2 for that way. Seems to work pretty well.I always though the small choil between the blade and the plunge line/ricasso/guard was for dragging ferro rods. Square that part up. At least, that's what I've been using.
That wasn't put there for a ferro rod thou it may work. The actual purpose of it is for sharpening, that way your stone can make contact on the entire edge.I always though the small choil between the blade and the plunge line/ricasso/guard was for dragging ferro rods. Square that part up. At least, that's what I've been using.
I could be wrong but another thing that might determine if a knife will come with a sharp spine is heat treat. Some knives being differentially heat treated the spine is too soft for continually striking a ferro rod. I've seen several people complain that after filing the spine on there tops bob that after a few strikes it would no longer work.
Would probably have to been used many many times to result in any type build up to cause it not to work...plus a quick wipe would remove atleast 95% of any residue. If the steel is softer due to differential heat treat the ferro rod would be harder and result in it dulling the sharpened spine.That's an odd thing. Of course, in thinking about it, would build up of material/sparked residue in the area being used be a factor in that result?
