I have No idea how you could come up with this idea...
If it is true for those two materials, it is not unlikely that it is true for other materials.
Every material is different, that is why we build cars and skyscrapers out of steel and not Only glass. Otherwise we could Heat sand and make creating buildings Much more cost effective. Hell, we could even Cast buildings then...
On a more serious note.
Wouldn't the innate hardness of glass and its lack of ductility be a leading cause as to why this arguement against steel having a 90° angle be all for naught?
I could see that an argument be made for plastics If, and only if, the forces exerted and the rates at which deflection, rebound, hardness and toughness were measured and found to be in scale to a certain type of steel and then the chipping scaled along the same lines of progression.
To make a blanket steel, glass and plastic comparison is no bueno
There are many types of plastics, and I am sure some make a better lense then others (think polycarbonate vs hdpe). So wouldn't those essentially be comparable to differences in steels? Some are more prone to chip (zdp-189), some are more tough (s7, d2). Using my examples here, those that can't take as keen of an edge likely wouldn't chip in the same instance. Steels themselves shouldn't be compared in such a manner (I wouldnt expect a zdp-189 spine to take the abuse of a 52100 spine both @ 59hrc).
I am only stating this because there has been a blanket statement regarding the similarities between steel, glass, and plastics and I don't feel that all that much of a direct comparison can be made. Considering the differences between the three are substantial.
(From here on out, lense grade plastics will be referred to as "plastic" for my fingers ease, typing this on a phone)
-Glass chips conchoidally (likely plastic as well), steel doesn't
-Steel is Much more likely to deform under excessive load, glass and plastic break
-Steel is reactive to elements, at least more so than glass
-Most steels can take a higher side load at a 20° angle or a 60° angle than glass or similar plastics due to the ductility and toughness.
I would think that glass and plastics aren't all that similar to steel in regards to a knife aside from they can both slice something. That is why we progressed(?) away from knapping flint and chert.
While modern companies cannot make a scalpel as sharp as the edge on a piece of obsidian, they can make an edge that will last significantly longer due solely to being less likely to chip because of steels superior toughness.
Hence a 90° on steel is not comparable to 90° on glass or plastic.
