why not use bigger pivot pins???
is there any reason not to use really big pivot pins like 3/8" or bigger in a knife???
I'm a Schizophrenic and so am I
It's a design thing, overall package, width of blade, 3/8" pivot in a blade width of 3/4" would not leave much "meat" around the hole. Bigger wider blade would probably be fine. Come to think of it I may have seen a knife like I described above.
Sola Fide
yeah thats what i thought i was just wondering if there were any other reasons like if it would cause too much friction
actually bigger is probably better for a number of mechanical reasons...but when you start getting above 1/4" you run into the problem stated above....theres really not a lot of room there. i think a bigger hole would provide more surface area and therefore a better stronger action.
http://www.mayoknives.com
one of the factors that dictate the size of the pivot is the surface area that blade sides and liner have in common. If it is too small (large pivot on smaller knife) this surface area can't give the side strength required to make a strong knife. The thrust washers (locking liner type knives) need to be large enough to provide this surface.
Hope this helps
old pete
