In a word, no. You could use hidden pins, but the pins are there to give shear strength, so they must of ample length to do so. If you were to drill a series of holes in your tang, they would allow the epoxy to form bridges from one slab to the other. That gives great strength to slabs that will allow a good bond. Oily type woods will not. BUT, you still need pins hidden or otherwise for insurance. I once had to remove horn slabs from a knife I made using pins and many hole bridges. I was able to punch the pins out with not too much trouble, but after beating those slabs with a 4 pound hammer, and no success, I had to burn them off. Even so, I would still recommend at least hidden pins. The epoxy was the much maligned Devcon 2 Two Ton.
Post does not compute. You say you need pins and then demonstrate that you don't.
Without a doubt you can make a good kitchen knife handle without pins, and even if the bond failed failed a kitchen knife handle separation is not catastrophic, i.e. you don't need to buy the insurance of pins. You can choose to, but you do not need to. You choose to use pins, I choose not to.
OTOH for several other types of knife that the extra insurance is wise, on knives that see hard use far from home.
I personally like pins myself - at least visually. I had been trying to figure out how to get the pins done properly. I had already drilled the holes in the steel prior to gluing but I couldn't figure out how to drill the holes in the scales and have them marry up properly with the holes in the steel. So I glue them on with no holes. I figured I would try and drill the holes in the scales while they're glued to the knife. Is this acceptable?
Also while I'm on the topic, I want my pins to be 1/4" diameter. The next size up in drill bit (I forget the size) makes the hole slightly too big and leaves space around the pin so it flops around in the hole. How do I drill a hole just ever so slightly bigger than 1/4"? I know this is childsplay for many of you but this is my first knife. I expect to make many mistakes so I'm not worried about messing up. I have six knives in progress at the moment but this particular knife would be considered my first.
Thanks so much for the help guys. This forum teaches me so much.
I don't think you read my post fully. I did not advocate using epoxy only, and I would not. I am only saying that with epoxy bridges there can be great strength, if the material used takes a good bond. I would pin regardless. You are free to do as you please, but I would never buy a knife with grips held only with expoxy. Hengelo, hidden tangs are a different matter than slabs. Even cutlers rezin will hold well on a hidden tang.
The real question is- "Why epoxy?"
Properly used mechanical fasteners make any glue unnecessary.
I like the way you think.The real question is- "Why epoxy?"
