- Sep 5, 2006
S90V is easy to sharpen. I bought a Spyderco with it and it was used, not sharp when I received it. I could bare believe how easy it became sharp on ceramic rods.
I find it extremely easy to sharpen/touch up on ceramic stones. I do this often when they get chipping in my spyderco and benchmade s90v.S90V is easy to sharpen. I bought a Spyderco with it and it was used, not sharp when I received it. I could bare believe how easy it became sharp on ceramic rods.
You're thinking of s35vn.
Yeah, ok.Well, not really. S30V has been the all-out star of Spyderco for years, and only recently has S35VN made an entrance. Check out the ParaMilitary 2, Military, and other models sometime, and see how many folders have been made and sold in S30V, compared to S35VN... Probably 50 to 1.
Cliff ommits saying what he uses to sharpen the main bevel with. In the article mentioned above he only states about microbevel. From earlier articles he sharpens s30v like so.
Then 1000 diamond Wicked Edge micro.
- Suehiro 'Chemical' 320 grit
- Naniwa Superstone 400 grit -or- King 1000 grit
- Naniwa Aotoshi 2000 grit
Its from this forum i learned you gotta use diamonds to abraide all of the vanadium rich steels properly and the rest of the CPM evenly distributed hard carbides.
So this kind of neglect on his behalf opens other possibilities...
The numbers on the right is knoop hardness.You might tell Phil Wilson to stop using silicon carbide to sharpen high vanadium steels and switch to diamonds.
time will tell whether the hazel nuts will fall out or not.
I dunno what this guys saying, but he is testing s90v in the video. puts it through some stress. if he's saying something interesting about s90v that would be great to know what. otherwise he talks too much. i think its Russian? i assume he tests s90v at 60 and 62hrc?
Yes that was what I was thinking when I saw Jill Jackson's use of the ceramic rod on S90V.I don't know i just use the right tool for the job.
That's no doubt how we sound to them. With maybe a little vocal fry thrown in.Youtube video now have a language translate feature, just turn it on and select what language you want it to translate into, the result can be quite hilarious.
John.
Is he wearing dinosaur pajamas under the camy?
I like m4 as much as the next guy, but if the same knife in d2 or 154cm is $60 cheaper I'm going to buy it instead.
im incline to say you may be correct. its super easy to use them to sharpen the edges of s90v, but... its moving metal rather than cutting it maybe? which is causing chipping more than it would with diamonds or cbn. or so im guessing here. i did get chipping when using diamonds on my s90v also.I think the ceramic rod is NOT a good tool to produce a sound, long lasting edge on high vanadium alloys. It's just not hard enough.
Whoa, whoa, whoa. NOW you're telling me he lives and test knives at the North Pole? That, sir I refuse to believe.
Hey . . . don't knock The North Pole !Yes, that is exactly what I meant to say.![]()
