For me , I have had Mora since I was a teen . And my Mora were always sharp .
I found it relatively easy to keep a scandi sharp , even when struggling with normal edges .
Once I purchased a ceramic rod , I used that ceramic rod exclusively to sharpen my Mora's .. I used nothing but that ceramic rod for a good 30 or more years . ( Im getting old , forgetting how long I have had Mora knives )
That meant I was doing the micro bevel on the knife rather than maintaining the Scandi edge . ( But , easy is easy )
Now some people have issue with sharpening Scandi ..
I think , you need to find YOUR style or method ! Fair enough if you see a Utube video and your able to copy some one else's method .
Back to why so many people like Scandi ..
A) It just cuts so well .
B) For me anyways , easy to sharpen .
C) Easy to maintain .
D) Easy to restore
Yes , maintaining a full or real Scandi edge is a little more work , but you should be able to strop the edge back for quite some time . This helps keep stone work to a minimum .
Or you can go the micro bevel route . ( I mean , I did for 30+ years ) .
& I only changed after I started chasing after edge retention .
+ I find maintaining the Scandi much simpler than a regular knife , especially hand sharpening .
The guided knife sharpeners have changed things some , but what if ? This N that meant you no longer could access them !
That's why if I knew something DEEP "S" was coming my way , I would be packing Scandi ..
In fact , I never went bush without a Mora ( Never ) . Sure there were other knives , but always a Mora as well .
These days there are more options ( Brands / steels ) to chose from . Still , I think there will always be a scandi in my life at home or in the woods .
The video is Mikey Mouse : ( Yeah )
But might give people some sharpening ideas of their own .
D) Easy to restore
