WadeF said:This is true, and believe me, I've tried.I shave with straight razors which have a much thinner edge on them than a knife. If the straight razors aren't just right they pull and don't shave that comfortably. It isn't until you acheive a finely stropped edge on a straight razor that you can comfortably shave, and that's after you properly prep your beard with good shaving soaps, pre-shave gels, oils, etc.
Oh and lots of hot water.
holst035 said:A shaving sharp knife in your pocket, is that really necessary? For what purpose can I possibly need such a sharp knife?
cut_n_run said:"Conable said the ZDP core with the 420 stainless exterior makes it extremely easy to sharpen " [emphasis added].
-from Feb 2005 Blade
Jeff Clark said:When I dissected frogs in high school I used my pocket knife rather than a scalpel.
Sword and Shield said:I did the same thing in college- cat dissection with a SAK Recruit. My scalpel was sharp enough- they didn't let you use your own- but my knife was better.![]()
Jeff Clark said:When you get really serious in a kitchen you do less slice cutting and more push cutting. Slice cutting takes extra motion and tends to slide your food around. When you have a lot of food the efficient way to handle it is to stack it up and push through the stack with several parallel cuts to make multiple strips or slices and then rotate 90-degrees and do it again if you need to make cubes or short strips. That is the reason for the shape of a chef's knife and why the chef's knife is the primary knife in the kitchen. This is one of the reasons that I own very few serrated knives. This is also the reason to have a cutting board (or several) in the kitchen. A very thin edge will stay sharp an awfully long time in the kitchen if you use a good cutting board. I commonly hone 10-degrees per side on kitchen knives with no durability issues. If I want to chop bones I use a thicker edge and a tougher steel, but otherwise I use as thin an edge as possible on every type of kitchen knife.
Slicing action comes into play more when you serve already cooked food such as meat or bread. In the case of meat, a sharpened butter knife would work perfectly well for an awfully long time since cooked meat is easy to cut (table knives are often unsharpened butter knives). In the case of bread, serrations or a roughly sharpened blade are what is called for. All but a couple of my serrated knives are bread knives. A serrated blade only works when you use a slicing action. It takes extra motion to use one on a cutting board. I sometimes give one to an amateur if they are trying to bone raw chicken. If you aren't dextrous it can be a hastle to cut rubbery raw chicken without draw cutting.
DGG said:Some can chop veggies with a chef's knife but I think that for the most part they use slicing more than pushing.
