- Aug 31, 2014
Yes it does make a huge difference. Again..... they made that grind for strength purposes.
It wasn't useless, gotta learn by asking questions. Read ahead a lil bit next time so we can all be on the same page![]()
Buckman110, was that grind used on any of the fixed blades of that era like the 103?
But isn't that what a forum is for? Information, chatting about whatever the subject is at hand?
I will continue to ask away, thank you very much. But as stated earlier, my post was a statement, not a question; and your intent did not seem to be friendly, rather it seemed to be an effort to stake your own superiority. I suspect this is the kind of stuff Haebbie was talking about in his recent post.Please feel free to ask away
It wasn't as important as all this sturm und drang would suggest. Sorry for the needless detour.
I just posted some fixed blade examples, as you had asked about, from my own humble stable, two 105s. One (the newer, c.1972 one on top) has a very pronounced semi-hollow grind and the lower one (a few years older, 67-69) appears to have it, but less so. Honestly, I have to dig the older one out since it got packed away after it came back from the spa. But the pictures clearly show the grind feature on the top one. For many many years, the older 105 was the only Buck knife I owned, so I assumed that to be a common feature of knives of that sort. It was only later that I realized that particular grind had changed over time. Anyway, I wondered then (and now) why that grind developed and changed. I've not put the knife through the kind of rigorous paces that would show me under what circumstances it is superior or inferior to other grinds--not that matters much anyway. The hardest use it sees is in the kitchen, where it seems to do really well.
If you're interested, I'll be happy to send you the older one if you want toplay with ittest it out.
Older 110s like some of the 2 dot 110s have a peculiar hollow grind that gets thicker just above the edge.
Here's one of several old threads on the subject .
The question is, Why did Buck use this grind?
I really like it. Better than the current grind for wood, IME. But I'm wondering about why Buck might have used it?
