I actually addressed that in the post you quoted:
"Ringed and waved karambits might be the pinnacle of this, as you are likely also already in a proper grip and ready to go by the time the lock engages, where other waved knives would likely require a little repositioning as you finish drawing the knife."
That's what I was referring to; waved karambits are generally designed to be drawn from a position where the blade spine is anterior in the pocket, and the ring allows one to draw into a natural dagger grip without readjustment. Much like the benchmade SOCP, drawing with the index finger (or pinky, depending on how you plan to use it) puts you in a perfect position from the get-go.
Now that we've hashed that out, let's put away our Tom Clancy novels, take a cold shower, and get back to nerding out about how AO knives are for uncultured plebs.
^This is an excellent point. Often AO can be used to cover up poor quality and fit/finish. Another main reason I dislike AO is the lack of closing detent ball. I don't like relying on the AO mechanism to keep the knife closed. It it breaks the knife can open at will.IMO, consciously or unconsciously, we like non AO better, because we know they (AO) are less refined...
Head to head, AO knives tend to "usually" be cheaper then their high quality counterparts. The AO mechanism seems to me, to simply be a way to overcome small deficiencies in overall build quality. A well built and refined (and usually comparatively more expensive) knife is built to tighter tolerances, and they usually can and will open as quick and sometimes even more effortlessly as any AO.
Whereas AO snaps open, it also has more moving parts, which also means more parts to potentially fail, and so, while often more affordable, and "does the same thing", the level of overall refinement is just typically not there, and we enjoy quality mixed with simplicity in one of the oldest tools known to man. So a well executed manual is preferred.
I honestly do not think an auto is any faster than a good manual knife, particularly a flipper. In the same ammount of time it takes for me to push a button with my thumb I can push a thumb stud or a flipper.
He's talking in a practical tactical type sense. Doesn't make much sense here in gkd but it would in that particular subforum.Why do we care how fast a knife opens? I can't recall ever having a cutting task that required a fast deployment.
n2s
Self Defense? Beyond that, I agree. My Case traditionals can open the same clamshell packaging as any assisted knife and I would hope that my chances of having to pull a knife quickly to defend myself are less than negligible.Why do we care how fast a knife opens? I can't recall ever having a cutting task that required a fast deployment.
n2s
I'm just picturing carrying right-handed tip down in the right front pocket, and the hilarious circumcision related hijinks that could ensue.AO is not a deal breaker for me. I really like my Leeks, and the Mini Barrage is one of my favorite knives. Carrying tip-down obviates much of the risk of opening in the pocket (just as with a floppy Opinel), and has little to no effect on ease of deployment. The issue is largely moot for me in any case, as I carry OHOs only infrequently.
Yes.If anything, folks should practice drawing from concealed and firing off two accurate shots. This is where speed can actually save your life.
Yes.
Another reason I dislike AO is they are not fully one hand open and close for me. I have to put thought and technique into closing an AO knife. One of the main reasons I carry a modern one hand opening knife is the convenience of opening AND closing with one hand. Often times I'm holding with one hand what needs cutting and use more other hand to extract, open, cut, close, and put away the knife. Sometimes this happens in compromising positions like on a ladder. Easy one hand opening and closing is essential for this. An OTF auto is ideal.
