why use thick washers on liner locks?
I was wondering why some companies, like Benchmade, use thick washers on their liner locks?
Dennis Bible
Jackal
Basic Member
Probably makes it easier for them to service and make small adjustments to by adding a thicker, or thinner spacer. Dunno for sure though.
-AR
- AKTI Member ID# A000322
two things...for the most part preclude thick washers....first loose fit on the pivot barrel and the pivot hole...sometimes done on purpose to make a quicker knife.. and second. the tanto and fighter styles that have a flat in the middle of the blade or a flat down to the point, will scratch up pretty bad without a thicker washer to keep the blade away from the titanium liners. there has to be some play or the knife wont work...just like a brand new bridgeport comes with about a .001 backlash...if it was .000 it would lockup.....and when you push on the thumbstud or hole or whatever, the blade deflects in that direction... hope this answers the question...
http://www.mayoknives.com
Thank you for the answer. One more reason why I love the forums. Where else can you have a question ansered by such experts?
Dennis Bible
