Yes, hard, inertial openings have been known to deform certain locks, like liner-locks can slip this way, or a lockbar can deform. I do not know if an assisted open is hard enough to do this on the average knife, and I'd also assume blade size/mass would play a part in that. Quality, too. Had an assisted folder that I bought once a long, long time ago at BudK, fall right down onto my finger when the liner-lock slipped to the other side upon a normal use of the assisted flipper.Should a knife be flung open that fast anyways? Even with a no assisted thumb or flipper..is whipping it open shortening it's life span? I ask because I do not know
They make an SD Classic in it that is quite nice - if you like blue donuts, you can also score the SMKW version and if the SD Classic is too small for you, they have a Tinker with this color scheme. For this particular color scheme on the SAK, I rec a slip with it because the pattern on this one may wear if rubbing against things like keys or whatever.I love that one. I wish they would make other types of knives with that color scheme.
I agree that an automatic knife is absolutely no "faster" than a manual flipper, thumbstud knife, or Spydiehole, backlock, comp lock, whatever. I can flip them all open more-or-less from "there" to "not there" regardless of lock or opening mechanism, heck, as you mention, I can open my Leatherman about as fast anything else, might be a slight difference, but it is basically "there".Back to the OP question though:
I cannot justify for myself, the use of an automatic knife. There are plenty of "flipper" designs that allow one handed deployment with ease. Even my Leatherman Wave can be opened with one thumb if you are careful . . .I can't do it due to a operantly dislocated thumb.
Spring assisted and switchblade operation are really neat though. At age 12, I had a stiletto my folks never found about, {which was part of the fun) I wore it completely out as a spin-fidget toy in a couple of months. . .. before I turned 13.
If there is no stress in one cycle they exceeds the thresholds it was built to, I think it should handle basically endless cycles. I've never really heard of a knife wearing out from being flicked open. It's not much force ultimately, even for small steel parts.Should a knife be flung open that fast anyways? Even with a no assisted thumb or flipper..is whipping it open shortening it's life span? I ask because I do not know
That's my reason!Arthritis?
Wow! Lots of opinion laden posts. Here is one more:
Because so many states had made auto knives illegal, many of us who had been using autos for work often chose to purchase the assisted opening knives to use as a substitute for auto knives until the tide turned and autos became legal again. Some of us have needed to open and close a folding knife 100+ times a day and auto knives are very preferred.
Assisted is kind of like (I'm drawing a very loose parallelhere).357sig. Was a cool idea at the time, but the base product it was designed to improve has now improved itself to make its "better " obsolete...
This is why I said I was drawing a loose parallel here. It was not a great comparison. I was exhausted and attempting to think.I disagree. Assisted action was an easy answer to great manual actions being rarer or more expensive. As an approximation, it always had limitations. It has largely been rendered obsolete by the proliferation of great manual action at lower prices (at least outside of protected environments like the Walmart knife counter).
The .357 Sig wasn't a patch for some deficiency. It was a great idea in its own right. It closely approximated the ballistics of then-popular 125-grain loads for .357 Magnum in a semi-auto format that allowed for double the capacity (or more) plus quick magazine changes. It remains an awesome round at lighter weights, either in hollow-points for humanoid threats or solids for animal threats.
Some people argue that .357 Sig was rendered obsolete by better loads in 9mm but that's not exactly true. It takes a very hot +p+ load in 9mm to approach what .357 Sig was designed to do all-day at standard pressure. The real issue is that as 9mm loads have improved--and other factors have come into play--law enforcement agencies have re-embraced 9mm and the market has followed suit. Meanwhile, .357 Sig already held a minority share of the market and we've been hit with wave after wave of scarcity issues largely driven by government. Now even .40S&W has fallen by the wayside.
I love the Leek (much more than I ever expected to), but it would be even better without the assist. I could take it out of the house, for one thing.Yes, this! ^^ Get you a Kershaw Leek, use it for a while, and see if your opinion changes…![]()
