Wicked Edge Field & Sport Pro model We-102pr1
Feedback: +18 / =0 / -0
Open to trades for higher end folders at approx 3" blade length, striders, hinderers, high end Benchmade's etc. Also open to infi Busse's. I can add cash for the right deal. Also listed in for sale
New in box, never used Wicked Edge Field & Sport Pro model We-102pr1. It appears this has been discontinued now.
https://imgur.com/a/54ksjsI
Description from site*
WE102PR1: Field & Sport Pro Sharpener
Wicked Edge
Wicked Edge makes the finest sharpener design on the market. They are really in a class by themselves. So, if your knife is in a class by itself, you should probably get the sharpener that can put that factory edge right back on it after every use. Now available in a travel version!
The Field & Sport Pro Model is a portable version of the Wicked Edge with the Pro-Pack II hardware, a precision engineered, manual sharpening machine. It was designed with very exacting standards to consistently deliver an incredible, razor sharp edge. While the results are excellent, it is easy to use and does not require special knowledge or skills to use. This is the easiest way to get a hair popping edge on any knife and you can take it anywhere you need it with the custom made travel case.
Features
  • The Field & Sport Pro Model features a lightweight carrying case and easily clamps to any firm surface with the included C-Clamp. There is a simple, easy to use angle adjustment with 1° increments ranging from 13°-35°, ball joint pivots and micro angle adjustments
  • Upgraded Pro-Pack II angle system with ball joints and micro angle adjustments
  • Machined from aircraft-grade aluminum, stainless steel and space-age composite materials
Field & Sport Pro Includes
  • The Wicked Edge Field & Sport Pro Sharpener (includes 12 Diamond Stones, 2 each in 100, 200, 400, 600, 800 and 1000 grits)
  • Carrying Case with custom foam inserts
