It took me a long time to learn to sharpen well on stones. But it was worth it. Now I feel comfortable sharpening even my most expensive knives on stones. Get a Wicked Edge and love it, but I suggest learning to sharpen as well. May not always have a fancy sharpening doohickey out in the sticks. I've had to sharpen my knives in the woods away from sharpeners, and I did it on a truck window and stropped it on my boot and it shaved. It's a valuable skill. Best of luck in whatever you do-- Tink
I learned how to sharpen from watching youtube videos and practicing on some old stones my uncle gave me. The Wicked Edge takes a lot of the guess work out of the equation, but there is no substitute for a good understanding of what sharpening does and what "sharp" really is.
Ive been looking at the wicked edge but what worries me is some photos of knives Ive seen sharpened on it have very uneven bevels. The bevel is super thick near the tip and thinner near the heal. Seems you really have to be careful how you clamp the knife to avoid this.
I assume when sharpening freehand this isn't as much of an issue....but the learning curve is much greater...
Yeah i looked at the pro kit and for what its got its a lot better than the basic one just because it has a better range of stones and strops and it comes with the base even though making one wouldn't be too hard. I actually sold some stuff on ebay and managed to save up the $390. now its a matter of getting the WE or getting some nice Chosera waterstones. It just seems like the WE is more convenient but requires more setup. Although the am drawn to the "zen" of the waterstones and traditional sharpening style. But like you im too afraid to use my expensive knives
I did basically this progression of "get guided and practice freehand" using an edgepro and one of heavyhanded's washboard systems. The washboard gives extra feedback using an acrylic plate that's gridded that you tack wet/dry sandpaper and computer paper loaded with compound over. It really helped me to get a feel for following the bevel heel-to-tip, and also provides a really nice stropping substrate for regular maintanence. It's less than $50 and would be a nice supplement to the WE or whatever other guided setup you choose.
I found on my edge pro that doing touchups was sort of a PITA when i had to get the system out, mechanically match the edge angle, strop, and put everything away. I imagine dealing with a clamp would add more time to the process. The washboard (or any other freehand strop) allows you to learn the muscle memory and body mechanics of following the perfect bevel that you put on with your guided system in significantly less time than using the guided system itself. That not only helps to refine your freehand technique but also makes you more likely to do regular edge maintenance, which should stretch out the intervals between needing to crack out the "big guns," so to speak.
Whatever you choose, I'd encourage you to look into a strop of some kind, and I'd personally recommend checking out the washboard system because it provides such positive feedback to let you know when you're on the flat of the bevel and when you're riding to high or low.
Enjoy the foray into sharpening and may the unicorn of "sharp enough" grace your blades often!
(I'm not in any way associated with heavyhanded outside of being a very satisfied customer!)
Again, just because you have a WE doesn't mean that you can ignore what sharpening is. And what is "sharp" can be very difficult to define without some empirical data. What I define as sharp and what you define as sharp are relative without a way to test and data to compare. Coincidentally this is something else that Clay has been working on, he has a sharpness testing rig, and posting about in the WE forums.
I never said that having the wicked edge means that you can ignore what sharpening is. I was trying to say that even if he gets the wicked edge, he will still have to read and learn about sharpening.
The wicked edge field and sport pro is $ 410 and I believe includes the pro pack 2 stuff.
Can you mount that on something fixed? it looks like that rectangular bottom piece is a different version completely and has to be clamped to something
Of the two choices, I'd suggest the Wicked Edge.
So you'd say get a WE and then grab a strop and get the technique down and later on try with stones? where abouts can I get the strops?
Edit to add: there is no option out there that will work better in the long run than learning to freehand no matter what tools you settle on - no substitute for owning the process and the results, and being able to work with whatever is at hand.
