thats what I would doSo at this point I am leaving well enough alone (I say this now). Knife is sharp and will be a user. Will correct slowly with each sharpening or take it to 15 degrees and even it out. Frankly, it’s not that bad.
Yep, pulled out the angle cube to help. Geometry, guess I should have paid attention in class more.Guided sharpeners.... it's all about geometry.
Let’s say, I put my EDC in the clamps of my sharpener. On my sharpener the distance from the pivot to the edge of the blade (in the center of the clamps) is 220 milimeters. If this distance from the pivot to the edge changes then sharpening angle also changes.
Yes, he would get the same bevel angle and same bevel width if the metal is uniform in thickness. I tried to explain this above.I'm wondering if someone tried to put lets say 150 milimeters long straight strip of metal in the clamps and sharpen it. Would he get the same angle (same width of the bevel) along the whole length of the strip?
Many people get confused on this issue because they think in terms of plane geometry, but the issue is solid geometry.Hmmm, I would say you would get wider bevel from sides.
Lets say you start grinding at the center of the clamps and you move the stone to one side... more you move the stone to the side, wider will be the bevel.
No, because the stone can rotate about the arm of the sharpener.I found a nice example if anyone stil listening to me...
Lets say we still have straight piece of metal in our clamps and we want to sharpen it.
If we want to have the same edge angle (same bevel width) along the whole edge of our straight metal we would need to have our stone perpendicular to the edge of our metal in each point along the whole length.
With our sharpening systems we can't do this because our pivots are fixed. We would have be able to move our pivot from lets say left to right.
