- Jan 6, 2005
Very good.... prying, chopping, feather sticks and THROWING TARGET all in one!Breaking down pallets is perfect for that.
Example said:You start off on the edge of a forest in a post apocalyptic zombie world ("The Walking Dead" TV show seems to be a popular forum topic at the moment). Across a grassy field you see an old abandoned armory. The goal is to get inside the armory and get supplies inside. The challenge that the knife suffers a catastrophic failure on, or fails to perform the task within a reasonable time frame, is when the maker "dies" from zombies.
Challenge #1: Zombie Ambush
Quickly make a spear capable of fending off multiple zombies (how quickly/easily can it carve hard wood into a spear).
Challenge #2: Close Quarters Combat
Your spear broke; hack and slash through the remaining zombies (cut through an animal leg of some sort).
Challenge #3: The Outer Perimeter
You've successfully fended off the zombies... for now. After crossing the field you come to a chain link fence surrounding the armory (either cut through a section of chain link, or successfully bust open a lock).
Challenge #4: Stranger at the Window
You've checked all of the doors, but all of them are solid and bolted up tight. But there is a small window in the back. Smash through the window to gain entrance into the armory (breaking glass and/or cutting through mullions and transoms (wood/plastic)).
Challenge #5: Smash and Grab
In the armory there are numerous wooden crates full of guns and ammunition. Break open the crates and grab what you can (successfully pry apart, or cut through a pallet).
Challenge #6: Knock, Knock, Knock'in at My Door
The remaining zombies have crossed the field and are looking to get inside the armory. Using pieces of the smashed up crates and the crate's nails board up the broken window to buy some time (use your blade as a hammer to drive nails).
Challenge #7: Dude, Where's My Car
You find an armored car in the Armory's garage. However, before you can hot-wire the car you need to hack through the slatted sheet metal armor covering the windows (cut through a section of sheet metal).
Challenge #8: Release the Hounds
Before you can leave you need to tie down your supplies. Search the armory for a length of rope or cable to secure your cargo with (cut through 1" rope or 1/2"cable).
If you've successfully made it this far you're home free. You get to live for another day.
I might have missed it, but whats our timeframe?
I'd like to enter this one! Looks fun for sure.
Mine is cut, profiled and ground.
I guess I probably should have waited to see what the testing was going to be. Hopefully getting yourself out of a concrete enclosure is pert of the challenge.
I had all these freak show, video game looking designs that I ended up trashing and going with a traditional pattern I am very fond of.
