will a dc motor work?
after reading a bit I saw a few guys using DC motors to power their grinders how are they doing this?
It looks like a treadmill motor. You may use this but the true Hspwr is much lower than 3.
https://www.surpluscenter.com/item.asp?UID=2009071720574380&item=11-2102&catname=electric
[\QUOTE]
That's basically the same drive that I have controlling my grinder with a permanent magnet 2-hp Baldor motor.
I wouldn't recommend a treadmill motor for a grinder application. They are generally rated with higher horsepower than they actually put out, and are not rated for the same type of duty factor. In essence, they are disposable motors.
A good DC motor will cost well over $1000. The only way to go this route is to pick up surplus motors or find a good deal on eBay. I bought both of my DC motors there and payed under $200 each, including the controller.
Here's the motors I bought:
MOTOR SPECS HERE
Mike L.
I like DC drives and motors. I have used them for years without any problem.
The other option is a 3 phase motor and a VFD. Either way, the drive is often the bigger expense. Good motors (TEFC) of either type are available on ebay and other places cheap. Make sure the drive is matched to the motor. Forget treadmill motors for most shop uses.
DC drive, or 3Ph VFD -either one - once you go variable speed, a whole new world will open up to you.
Stacy
i can barely remeber. but isn't one of the draw backs of dc , that as you reduce speed you also reduce power(torque/hp)?
its not been an issue for me really... just a thought....
3ph motor w/VFD uses single phase 220v.
This is true but with a good controler, it's not noticed and the HP is not need at slow speed with finer grit belts.
K&G had 1.5 hp DC leasson motors dirt cheap a while back. Ebay's usually a good place to find a deal also.
