Fred.Rowe
- May 2, 2004
It depends on the pull through sharpener you purchase. The ERU has eliminated all of the negatives of pull through "V" sharpeners. Using the degree wedges supplied in the kit to produce a "flat" edge and then removing the burr using a matching angle on the ERU sharpener. The reason other pull through's do such a poor job is, alignment of the carbide surfaces. The ERU has two matching surfaces that make up a "perfect "V" shape along with an alignment pin that allows the user to hold the blade at the proper angle while sharpening. The two matching carbides have a small gap between them that allows the swarf to eject from the apex as the knife is sharpened.
If you like sharpening on stones or diamond plates, this kit will allow you to produce the finest "flat" edges and ones that are easy to maintain with the
Edge Renewal Utility. The sharpener can be carried afield in its custom leather sheath.
Once enough of these get in the hands of knife sharpeners we will no longer have to read about the negatives inherent in pull through "V" sharpeners.
The ERU came about after I spent 6 months tearing apart every "V" sharpener I could lay my hands on. After I figured out its problems I designed one that overcame these drawbacks. After all folks, what is the shape of a "flat" knife edge? It's in the shape of a perfect "V", which is the shape of the ERU.
I believe the ERU is the most accurate portable sharpener with the broadest angle range on the market today.
Check out our website. edgeru.com
Edge produced using this system: These edges are 400 grit off a diamond plate and finished with the ERU.
