- Dec 5, 2009
On the last knife I did, I used a beautiful set of Redwood burl scales from Burl Source's new knifemaker set. They were unstabilized and the only finish I did on them was to take them to 2000 grit and finalize with several coats of Tru Oil. I figured the Tru Oil, once cured, would create a fairly hard finish (as it has on a couple other items I've used it on). Well, the knife got marred up, and I am going to either have to strip the scales off and go with a stabilized set, or sand off the Tru Oil and refinish with CA glue.
Now, my main question concerns the use of another set of scales from that set; a really, really nice set of maple burl (also unstabilized). Instead of going the Tru Oil route, would a heavy dosage of CA glue applied in coats so it will soak in, work to harden up the outside of the wood to prevent easy marring of the surface?
Or, should I keep them for a knife that won't be worn everyday and get a set of stabilized scales?
Thanks!!
Craig Collier
Thanks!!
Craig Collier
