Wilson 4JR calibration help
Looking for some help understanding how to get this machine calibrated. I recently picked up a 4JR that has 3 anvils, all the weights, the original test blocks, diamond penetrator, and ball penetrators for a really good deal. The machine appears pretty clean under the top cowling and the dash pot appears to be at the right level of oil per the manual. I've adjusted the timing on the dash pot so that the plunger falls in 5 seconds. When taking readings, they are usually really consistent and within less than 1 point of one another. Based on several tests with two different test blocks, the machine is reading the HRC higher than the value on the block (60.4 block had an avg of 62.9 / 61.8 block had an average of 63.18). I was hoping the difference from the blocks to the readings would have at least been the same. I have already done the index level adjustment process described in the manual. Any ideas what my next steps should be? I know I need to order new test blocks, one was an original Wilson block, and the other is probably 30 years old but in good shape.
Makes sure your diamond is in good shape. Look at it under magnification to see if it's been damaged.
It’s probably the indenter, a worn or broken indenter will read high.
You might try changing the oil in the dash pot. Power steering fluid works good for this.
Hoss
If you want to try a new indenter here's one on Amazon for $22 B06XKWWPLH, just click a search with 2 day delivery. If you wish to wait longer there's some on ebay for around $15 shipped. just do a search for 145906337745
These are the same indenter as used on the HR150A clone so should work just fine on your wilson. If not sure check the measurements on your indenter and I'll compare them to what myu HR150A clone has.
I went ahead and bought the amazon diamond indenter. It seems to have corrected the problem. The machine read both test blocks within one point of the blocks. Interestingly, one read about half a point higher and the other was less than one point lower.
Just a note about test blocks: if the blocks you inherited have been used on both sides, that will skew the readings.
