If you have any questions, I can be reached at liukang187@yahoo.com
Benchmade 746 Lum Mini Onslaught 741/1000 First Production
LUM DESIGN - U.S.A.
AXIS LOCKING MECHANISM
154CM STAINLESS STEEL MODIFIED CLIP-POINT BLADE MEASURES APPROX 3"
AMBIDEXTROUS THUMB-HOLE OPENER
BLACK G-10 HANDLE SCALES WITH 420J STAINLESS STEEL LINERS
KNIFE MEASURES APPROX 4 1/2" CLOSED & 7 3/4" OVERALL
TIP-UP POCKET CLIP
PART OF THE BENCHMADE BLUE CLASS
COMES NEW, NEVER USED OR SHARPENED, IN ORIGINAL BOX WITH PAPERWORK
Wilson Tatical Model 1
Wilson Tactical Model 1 Integral Fighter. 10 3/8" overall. 5 3/8" 440C stainless blade with bead blast finish. One piece machined construction. Black micarta handles. Lanyard. Black Kydex sheath.
Mercworx Seraphym with 154CM
Specifications
Overall Length (inches): 5
Blade Length (inches): 3
Blade Material: 154CM, RC 58, Crygenically Treated
Blade Detail: Plain
Handle Material: Micarta
Carry System: Kydex Sheath
Like New conditon, never used, carried or sharpened.
Benchmade BM 800 AFCK PE ATS-34 w/Original Box and Paperwork
Benchmade BM 800 AFCK PS ATS-34 w/Benchmade Box
Both in Excellent condition, Sold as a Pair
Brand New Benchmade BM970ST
This was a collabration between Benchmade and Emerson. This is a super rare one with the titanium blade. I got this brand new but I didn't like the blade when it was closed so I sent this back to Lifesharp where they adjusted it so now it lines up perfectly centered when close. This has the paperwork from the adjustment. This comes with a Benchmade box.
ESEE-RC-4 Black Plain Edge Blade, Black Canvas w/Green Liners
New with sheath, paperwork and all Hardware
ESEE-6-6P-B Black Plain Edge Blade, Black Canvas w/Green Liners
Extrema Ratio Ultramarine Knife
Total length: mm 298 (11.73 inches)
Blade length: mm 150 (5.91 inches)
Overall Length Including Sheath: mm 320 (12.60 inches)
Overall Thickness Including Sheath: mm 55 (2.17 inches)
Weight: g 375 (13.28 ounces)
Blade Thickness: mm 6.3 (0.25)
Blade Steel: Bohler N690 stainless steel, X105CrCoMo182
Serrations: Partially serrated blade
Handle: Polyamide (Nylon)
Sheath: Double sheath
Diamond Sharpener: Yes
ADDITIONAL INFORMATION:
Comes with two diamond sharpeners: one is for the blade and the other is for the net cutter.
To protect the Ultramarine from damage when not in use, a flap is incorporated to cover both the sheath and the knife.
A strong pull will allow you to disable the O-ring and the retention system.
For entanglement emergencies, the Ultramarine incorporates a specialized net and line cutting system.
New with case,
LUM DESIGN - U.S.A.
TIP-UP POCKET CLIP
Specifications
Blade Detail: Plain
New with case,
