Zero Edged Snake Skin Nukarta Handled Mutant/Mr Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Marking It The Special Release Of A Modified Ergo Model.
Zero Edged Snake Skin Nukarta Handled Mutant/Mr Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making/Marking It The Special Release Of A Mojo Ergo Model.
Screw it, I can't think of another thing to add. Maybe a good nights sleep will bring something to mind in the morning, supposing somone doesn't slide in here and take it with something so blatantly obvious that we'll all want to kick ourselves in the pants. Good luck to those who keep trying after I hit the sheets.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Special Run Of Anniversary Model Engraved Mojos.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Special Run Of Anniversary Modified Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Special Run Of A Modified Ergonomic Model
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of A Modified Ergonomic Model
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Modified Into The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Made Into The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Made Into The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Modified Into The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Special Run Of A Modified Ergonomic Model
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of A Mojo Engraved Model
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Special Run Of A Mojo Engraved Model
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Made In The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Made In The Special Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Made In The Second Run Of Anniversary Marked Ergonomic Models
Ok, I solved it.
I have written the solution down and placed it in a sealed tube of PVC.
It is buried somewhere in the Pacific Northwest.
I could give you some clues, but I am not sure where I put the map.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Offered After Making Engraved Mojos
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Offered After Making Engraved Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Offered After Making Engraved Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Offered After Making Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Offered After Making Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Offered After Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Offered After Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Special Run Of Anniversary Marked Ergo Models.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Of Anniversary Marked Ergo Models.
got to be one of my last four tries huh??? huh?????
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Durable Coating Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of A Modified Ergonomic Model
Zero Edged Snake Skin Nukarta Handled Mutant Mojo With Durable Coating Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of A Modified Ergonomic Model
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Durable Coating Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mini Mojo With Durable Coating Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of A Modified Ergonomic Model
Zero Edged Snake Skin Nukarta Handled Mini Mojo With Durable Coating Or Satin Finish (Serial Number Inscribed) From The Busse Custom Shop Making It The Second Run Of Anniversary Marked Ergonomic Models
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut or Sunset Finish (Sheath Not Included) From the Busse Custom Shop Making it The Second Run Of Anniversary Marked Ergonomic Models.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut or Sunset Finish (Sheath Not Included) From the Busse Custom Shop Making it The Second Run Of A Mojo Ergo Model.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut or Sunset Finish (Sheath Not Included) From the Busse Custom Shop Making it The Second Run Of A Modified Ergo Model.
Zero Edged Snake Skin Nukarta Handled Mr. Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Of Anniversary Marking Engraved
Mojos
or:
Zero Edged Snake Skin Nukarta Handled Mutant Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custom Shop Making It The Second Run Of Anniversary Marking Engraved
Mojos
or:
Zero Edged Snake Skin Nukarta Handled Mini Mojo With Double Cut Or Satin Finish (Sheath Not Included) From The Busse Custon Shop Making It The Second Run Of Anniversary Marking Engraved
Mojos
