Winkler II Aggressor - Last Few Left!
Feedback: +2 / =0 / -0
Let us introduce you to the Aggressor by Winkler II Knives. You will find all the great materials that makes Winkler Knives great - 80crv2 steel, felt lined kydex fitted to each knife - all together, it's a blade designed for hard use, make you proud and last a lifetime.
This is our exclusive offering that will give you an on or off duty blade that can be concealed, kitted or all around on the job knife. Try to find what it can't be used for!
Take a closer look here: http://btacblades.com/collections/frontpage/products/wk-ii-aggressor-pre-order
$315, ships FREE
The Aggressor by Winkler II Knives is a custom built and design exclusively by and for BTactical Blades.
The Development:
We work closely with members of the Law Enforcement and Military community. A common request that comes in is simply for a knife that has a do-all approach that can be carried comfortably off duty but can still function as a primary blade on duty. This task seems simple but requires 100% intent behind each decision on such a capable knife. We approached Master Bladesmith Daniel Winkler with this idea. With our expert panel, we gave Daniel a rough draft and after some back and forth in regards to design - we nailed it.
The Innovation:
This is the first tanto blade offered by Winkler II Knives. It is also the first exclusive, custom order and limited run by BTactical Blades in a collaborative effort that was largely designed by our expert panel. This panel consisted of our friends in Federal Law Enforcement with Daniel leading the design for proper fit and function. The thumb ridge takes grip to the next level featuring custom jimping to ensure grip is maximized in addition to offering non-slip thumb pressure with or without wearing a glove.
The Knife:
Built to perform, the Aggressor can be concealed or set of for belt carry. The blade is ideal for piercing, slashing, prying, cutting and features a non-glare caswell finish to enhance corrosion resistance and durability.
Specifications:
Blade Steel: 80crv2
Blade Length - 3.75"
Blade Thickness: 3/16"
Overall Length: 7 3/4"
Steel Tang - Full construction, skeletonized
Sheath - modular with belt clip, slim profile and MOLLE adaptable in exclusive OD green felt lined kydex
The Build:
The knife is on schedule to complete by December/January 2016. With this timeframe, you will see it on display at SHOT Show for it's debut. This knife will not be massed produced and only available through limited runs and available here.
The Sheath:
In standard Winkler fashion, the Aggressor will come with belt loops to work vertically, horizontally, right or left hand draw. Additionally, it will be set up with a spring belt clip and MOLLE loops. The blade will sit firm and safe in a felt lined black kydex sheath in limited edition OD green.
