- Sep 6, 2014
I bring mules.
Nice! What kind of sleds are you using?
I bring mules.
We'll definitely learn a lot on this trip. Just hope it's not too miserable, which is why I'm trying to plan as best I can before we go.
I designed and built the white one, the others are modified kids sleds. A new mold needs to be made to make more.
Frankly if you are expecting to be miserable, I don't know why you would go in the first place. The idea is to have fun. I personally would choose the tent as it provides more of a shelter.
I was planning to use my 20 degree bag, 25 degree bag liner, two wool blankets, and my thermorest in the hammock. I also bring a mylar emergency blanket and have a thick decent quality emergency SOLE tarp that has a reflective side. Unfortunately, I haven't tested my gear during the winter, but my 20 degree bag and thermorest works fine during the summer. Nights could get into the 30's and 40's in that area. We'll end up having a fire as well . This will be my first test. What do you use for insulation? I thought about getting an underquilt for the hammock, but wasn't sure what brand or rating I should get.
I'm not seeing the upside for hammocks in the winter. It's certainly not weight, particularly in a group setting.
I like a floorless tarp tent, bivy, and 2 sleeping pads (ridgerest + thermarest).
Below freezing, air is colder than snow. More wind heat loss with a hammock.
The upside is comfort and I'm super toasty in my hammock and my -5f quilts are 62oz combined and I've been warm in them down to -15F with a 30F wind chill
I've used a pad in my hammock, and an underquilt. I had an ENO underquilt that my family got me, not a huge fan, and I have the DD Hammocks one. I've stacked the underquilts, and I've used just the DD Hammocks.
All three of those have kept me warm at Coopers Rock and at Seneca (and elsewhere) in the spring and fall. The underquilt was far more comfortable, and easier to set and reset when I had to get up in the middle of the night.
I used to snowshoe ten days at a time on the Long Trail or the Adirondacks
A tent
I could not imaging flapping in the wind in a hammock in sub zero weather
I want to be low and tight to the ground out of the wind
Stamp down the snow with snow shoes then with boots before you set the tent and you are already semi protected from wind
Good ground insulation
Blankets are heavy with little insulation
A rectangle sleeping bag as a wrap will give you more warmth than blankets and be lighter
Double and triple test your stove
Food and hot drinks will keep you warm
After that a fire
You seem to be carrying a huge amount of gear
Snow is a good insulator. If you get a chance and the snows deep enough build a snow cave. Haven't done it myself other than as a kid. Been out a few nights in winter and my favourite is a leanto tarp with a nice fire in front. That's if firewood is no problem. Don't know about gov parks
- Beannie, Wool base layer, snow pants, Smartwool sweater, Smartwool socks, Down packable REI vest, Down Mountain Hardwear Jacket, NorthFace rain jacket, gloves, and 3 pairs of Merino wool hiking socks.
- 3 season tent, thermorest, 20 degree bag, Sierra Design Thermal bag liner, a Wool blanket or two. The other setup would be the same but I'd be using the hammock, but it sounds like the groups expert opinion is to only do this if I have a high quality underquilt. I also have a SOLE emergency tarp that is pretty thick and one side is reflective, so I was thinking about trying to use it to provide additional shelter and build a fire to reflect the heat towards my tent.
- Jetboil Mini-Mo, light stainless steel packable grate, stainless steel pot for cooking and melting snow. Also, a stainless steel water bottle so I can add hot water or soup for me to bring in my bag with me. Figured it may help add some warmth in the middle of the night.
- Gransfors Bruks Small Forest axe, Silky Big Boy saw, a Survive! GSO 5.1, and a smaller folder or fixed blade.
Hot Chocolate by Pinnah, on FlickrAll comments are based on my current (and evolving) approach. YMMV.
I carry two hats. The first is to hike in and I assume it will be wet from sweat when arriving at camp. The second is a balaclava for camp. Keeps the neck warm which is a massive heat dump. If your base layer has a built in hood, the balaclava isn't needed, but I prefer a the balaclava over hooded under layers.
I don't carry a heavy 3 layer Gtx jacket any more unless I'm spending protracted time above treeline. Actually, I try to avoid taking rain gear all together unless it is going to be above 20F during the day. Rain gear is too sweaty and I prefer dealing with snow using non-rain gear outer shells (unless there is a risk for wet snow above 20F). I prefer a non-rain jacket nylon shell for hiking, preferably with pit zips. A $10 shell from WalMart is sufficient.
For moderate cold like you are going into, I wear my shell jacket above my sweater and UNDER high loft parka while in camp. On the trail, the high loft parka goes over everything. Putting the shell closer to the body creates a quasi-VBL and better controls the micro-climate near your core.
I go with 2 pairs of sock (one on, one in the pack) and 2 wool gloves (with leather shell gloves) and 1 super thick wool mitt (with leather or Gtx shell mitts depending below or above treeline). Gloves for most hiking but mitts for camp and for hiking in brutal cold.
I wouldn't hike in the snow pants and would save them for camp use. Softshell or polyester or nylon wind pants (preferably with side zips for heat control) over fleece tights. I hike/ski hot.
I would swap the wool blanket(s) for a Z-rest or Ridgerest. I always carry 2 pads in the winter, particularly with down bags which compress more than sythnetic bags. I want additional R-value UNDER me. I carry a ThermaRest but they can be punctured (ski edges, crampons, knives, branches) and a flat ThermaRest sucks in the summer but it catastrophic in the winter.
I recommend experimenting in your back yard with your sleeping bag, liner, down jacket combination. Loft = warmth and one thing to remember is that the more that you put INSIDE of your outer bag, the more you are compressing the bag from the inside out, thus loosing loft and making the system colder. Older style over bags (like the military system) rely on oversized overbags to minimize loft compression. You may need to use your 20F bag like a quilt by unzipping it 1/2 way and only putting your feet and legs in the zippered portion of the bag, thus allowing the liner bag and outer bag to both fully loft. I'll sleep in my thin down or primaloft jackets but never sleep in my huge Primaloft belay jacket for this reason.
I carry a small circle of thin plywood for my stove to insulate it. You may need to sleep with your cartridge. Experiment outside in your back yard. Leave your stove outside overnight and test it in the morning.
The places I go can't sustain the amount of timber harvest that an axe implies. For camping, I generally just rely on my stove but will also carry an Emberlit as a back up or for camp fires but this is easily fed with a small folding saw and 4"-5" knife.
I also see axes as a real threat in winter. One of the symptoms of hypothermia is clumsiness. Add fatigue and you have a recipe for mistakes. YMMV.
Excellent advice. I've used two down sleeping bags (a synthetic mummy bag rated to 0 F. inside a regular four-pound down bag) on a Thermorest in a tent at -40 in the Yukon, wearing polar fleece long sleeve top and long johns and was perfectly comfortable. Ground insulation is essential. My buddy had a cot and an alleged polar temperature sleeping bag and nearly froze -- no insulation under his bag. Wind can be a significant factor so I'd vote for the tent. Inside heating is not essential if you have the right clothes. Wear layers so you can take off clothing so you don't sweat on the trek in -- wet clothing can be a killer. Go all synthetic.Try your sleeping set up in the back yard before you go whether it is hammock or tent. Better to find out you need more insulation when you are able to bail inside.
