- Sep 27, 2004
Hello!
Its been some time since I posted here so I thought I'd throw up this little WIP to keep myself busy!
This knife is a custom order I am filling. While i've been making knives for years, this is my first real attempt at a kitchen knife. I've come to realize that the thin stock and ultra-thin grinds are quite a challenge and pose a new set of obstacles that I didn't encounter making traditional bowies, fixed blades or folders.
The customer wants carbon steel, differential heat treatment, had a design in mind and has a number of balance, weight and materials requirements. Not a problem!
I am starting with CRA 1095 in 3/32. This is some THIN stuff. I was a bit worried starting with an overall thickness this thin, and for good reason! The customer's design called for a 10.5" blade with a height over 2" at the widest.
I quickly mocked something up freehand on the barstock:
As you can see, I actually am making two at once. I predicted a high chance of failure with stock this thin on such a long blade and it being my first chef knife. Lets hope I don't need that second one!
Since the stock is so thin, I did a quick and dirty bandsaw job, knowing i could grind the steel off very quickly on the KMG:
I dont have many pics of the actual grinding process, but I do have some observations:
-Grinding steel this thin gets HOT and fast.
-On a 10+" blade this thin, even a small amount of pressure will bend the annealed steel. UGH.
-Grinding while trying to avoid creating a plunge line is a challenge and requires a lot of finesse.
In the end, the grinding went without much fanfare. As usual with 1095, I put a quick 200 grit hand-rubbed finish. I have never cracked a blade with the scratches running lengthwise. I dont know if this is just superstition on my part or force of habit!
Here's the blade at pre-HT thickess which was about the thickness of a dime. Its resting on my 1944 M-Head Bridgeport mill in case anyone is wondering:
Another shot to give a sense of size. Notice the Norton Blaze belt on my KMG. These are the kings of grinding belts if you have never used them. I find they dont even throw sparks most of the time...just a steady stream of metal filings. Also for you KMG nuts, look at my platen and you'' notice the old platen style of the original design. I've never got around to milling a recess on the left like the modern platen. This causes me problems sometimes but overall I work around it. I think I have one of the original KMGs as mine is marked "KMG-I" on the side and has the old size drive shaft, etc etc.
I'll stop here for this post. Next post I'll show heat treating.
